Results 1 to 5 of 5
Thread: About Adaptive Component
    August 12, 2011
    80
    06:07 PM
    I followed this clip :
    https://www.youtube.com/watch?v=cVTDJD3OGKQ
    I set work plane : Level 1, drew 7 adaptive points, 7 rectangular shapes by ref. lines, created form. When loaded it to conceptual mass, I could not apply this adaptive component on the way as attached image. Other ways, some times could, some times could not. ( When trying to catch the nodes, appeared a circle with a cross ).
    I still think that the Adaptive Points could be apply to any case ? What 's wrong ?
    About Adaptive Component-h1.png About Adaptive Component-h2.png About Adaptive Component-h3.png
    August 12, 2011
    80
    06:07 PM
    Unhappy
    Then I open a new conceptual mass... This time could not apply that AC to any way . Ooop ! About Adaptive Component-confused.gif
    My file :http://www.mediafire.com/download/68...kl/Family3.rfa
    November 21, 2012
    London, United Kingdom
    578
    06:07 PM
    I'm not a master at Adaptive Components by any means, but if your doing a repetitive component surely you only need 2-4 points, not 7?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    273
    07:07 PM
    All your profiles are facing the wrong way, you need to draw them on the other plane. Or do them as a family and place them hosted on that plane.
    August 12, 2011
    80
    06:07 PM
    Quote Originally Posted by tuekappel View Post
    THanks for reply. But I followed exactly the video clip, and don't know what was wrong. I tried to make the profile from another file and loaded it, but the same result.
    Furthermore, sometimes could put the AC, sometimes could not. The problem just happened when I put AC on nodes of divided surface, not on levels or references...
  1. Adaptive component question
    By BLothian in forum Architecture - Family Creation
    Last Post: July 4th, 2015, 11:10 PM
  2. Proiblem with Adaptive component
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 28th, 2012, 03:43 AM
  3. Problem when placing adaptive component
    By pjetrus in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 2nd, 2012, 10:37 AM
  4. Adaptive Component Help
    By djnelson75 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 3rd, 2011, 07:23 PM
  5. Family vs Adaptive Component
    Last Post: January 5th, 2011, 08:19 AM
