Results 1 to 2 of 2
Thread: Curved building problem
    June 11, 2014
    9
    10:04 PM
    Exclamation Curved building problem
    Hey,
    For school i'm working on a project/building that has curved walls.
    I already googled and youtubed a lot and at first, when i was testing this method (massing or model/wall by face) i thought it was working (see first attachment).
    But then after i made some adjustments to my autocad underlay (instead of the outline of the building being 'one line' i made it out of multiple lines so that i could make walls and curtain systems) and started over i couldnt do it anymore.
    I added some screenshots to further explain my problem.
    Curved building problem-render1.jpgCurved building problem-revitq1.jpgCurved building problem-revitq2.jpgCurved building problem-revitq3.jpgCurved building problem-revitq4.jpgCurved building problem-revitq5.jpg
    Orlando, FL, USA
    3,098
    05:04 PM
    One of the errors, the one that says "Can't divide curtain grid by grid line" could be that the length of the segment is too short for Revit to use the current type of Curtain System that you are using, which is set to a division of 1500 mm x 3000 mm. Try to redraw the shape without tracing from .dwgs, and with segments that are big enough to accomodate a curtain system of that size. Or configure the curtain system for a smaller grid.
    The other error, "Can't make face wall shape" could be due to the same cause, that you are probably picking lines from the underlay, instead of drawing new curves in Revit. If you just pick lines, you get all the imperfections and tiny segments of the .dwg file.
  1. Problem with adding custom curtain wall panels to curved curtain wall.
    By aktaylorh in forum Architecture and General Revit Questions
    Last Post: November 20th, 2013, 06:16 PM
  2. Curved wall not attaching to curved roof...
    By roseman5285 in forum Architecture and General Revit Questions
    Last Post: June 1st, 2013, 08:40 AM
  3. Problem dividing curved surface of conceptual mass
    By pavel in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 10th, 2012, 08:20 AM
  4. Problem with curved railling
    By thaihoalu in forum Architecture and General Revit Questions
    Last Post: May 28th, 2012, 12:15 AM
  5. Replies: 0
    Last Post: January 20th, 2012, 09:15 AM
Tags for this Thread
