Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Alfredo Medina
Thread: How to replicate these type of panels
    May 15, 2014
    14
    03:49 PM
    In an effort to make myself more valuable to the firm, I am trying to get more proficient in creating adaptive components and conceptual masses. They don't like to break the mold too much so curvilinear masses are out for now. I have found a lot of rectilinear geometries and systems that I find interesting and I think the designers here would too. I want to start replicating these so I can learn the method of creating these pieces (of course I am not going to steal them, just use them as a learning tool.)
    Here is an example of what I am talking about by SHoP: a f a s i a: SHOP ARCHITECTS. I am intrigued by the pattern created by the brick as well as the depth change and think it is a good place to start given the way my firm works and the types of jobs we get. I'd like to find some tutorials or literature as to how to create these types of families to give a presentation to the firm on the availability of these tools in the software that we already have.
    Any help or direction to help would be greatly appreciated.
    Gold Coast
    2,619
    06:49 AM
    Have a look at Zach Kron's Revit videos over at designreform.net.
    December 21, 2010
    C.LONDON
    4,382
    09:49 PM
    I believe SHoP did that in Rhino - there was a quite a write up on their work process for that very project. That's not to say it's not do-able in Revit, and I'd 2nd Elton's suggestion to check out Zach's work (he covered this kind of thing in the early days of his Buildz blog)
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    770
    04:49 PM
    Not sure of the entire process, but I think a portion of it was done in Revit. The customer gallery in Waltham has a display of this building with a bunch of 3d models and images. I don't think we would feature this in our gallery if it was a Rhino project. :-)
    December 21, 2010
    C.LONDON
    4,382
    09:49 PM
    Quote Originally Posted by JeffH View Post
    Revit Building 9 (!) going by the images on ArchDaily - with a little bit of Digital Project thrown in as well.
    Orlando, FL, USA
    3,098
    04:49 PM
    Seems to be possible in Revit. A pattern-based panel applied to a divided surface; the surface is made after cutting some holes for the openings.
    Attached Thumbnails Attached Thumbnails How to replicate these type of panels-06-07-2014-7-30-32-am.jpg
    Attached Files Attached Files
    snowyweston likes this.
    December 21, 2010
    C.LONDON
    4,382
    09:49 PM
    Nice solution Alfredo but I think the desire here might be the same as when I looked into doing something similar, in as much, to have the individual masonry modules in their individual locations with relative offsets modeled.
    Orlando, FL, USA
    3,098
    04:49 PM
    Oh, you mean, to model the bricks as in the photographs? Might take more time, of course, but should be possible, too. This was just a quick test to demonstrate that this is doable in Revit, if time permits.
    Member Andrew P's Avatar
    February 19, 2011
    362
    08:49 PM
    The bricks where modelled in Autocad, Rhino, Generative Component and Digital project. Not sure which sequence they used. Revit was only used for the usual coordination and documentation of the core. How to replicate these type of panels-3432131703_311cd3c39e_o.jpgHow to replicate these type of panels-3432131647_e9f3713541_o.jpgHow to replicate these type of panels-3432132141_8fa3dedc4b_o.jpgHow to replicate these type of panels-3432946718_65be673334_o.jpgHow to replicate these type of panels-3432946208_8caceaed02_o.jpg
    Orlando, FL, USA
    3,098
    04:49 PM
    The bricks could have been modeled in Revit as well.
  1. edit space type and building type database
    By ekkonap in forum MEP - General
    Last Post: August 8th, 2017, 04:50 PM
  2. Revit OpEd: Family Type as Type Catalog Flag
    Last Post: April 11th, 2013, 03:15 PM
  3. select by parameter? curtain wall panels' materials by parameter, by type or family?
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 02:20 PM
  4. NOOB question: delete callout type and section type?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: July 31st, 2012, 01:28 AM
  5. Buildz Bitmap to Panel Plugin - Cannot replicate sample file
    By tjgreatrex in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 21st, 2011, 03:03 PM
Tags for this Thread
