Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Curtain wall - Solar Protection Panels
    p.j
    p.j is offline
    May 22, 2011
    3
    04:58 PM
    Question Curtain wall - Solar Protection Panels
    Hey,
    Can someone give me a tip, where I can find Solar Protection Panels like in the picture,
    or how to make it?
    I need to make this form into panel like that -->
    Attached Thumbnails Attached Thumbnails Curtain wall - Solar Protection Panels-render.jpg   Curtain wall - Solar Protection Panels-freeform.jpg
    Member Andrew P's Avatar
    February 19, 2011
    359
    05:58 PM
    The solar protection panels where made with an in-place mass family. Here is the tutorial. http://www.youtube.com/user/Autodesk...13/_YWwqm7gtic
    p.j
    p.j is offline
    May 22, 2011
    3
    04:58 PM
    Yes, I know, I get this picture from this tutorial, but there is only shown how to create a form and I know how to make it, but in this video is used "Solar protection-MPK" and i have no idea where to get it from... or how to make something like that...
    It could be something similar like from revit opening
    thanks in advance for helping
    Attached Thumbnails Attached Thumbnails Curtain wall - Solar Protection Panels-solarpanels.jpg   Curtain wall - Solar Protection Panels-revit.jpg
    Member feio's Avatar
    December 13, 2010
    Decadent Lisbon
    450
    04:58 PM
    P.J
    Solar panels are like everything else in revit.
    You can do walls, roofs, families (in place or not).
    It's what you call it and how it looks that matters.
    For normal display, add a surface pattern and for render add a transparency mask.
    For everything else call what you modelled a solar panel and if you need add a manufacturer and model.
    By the photo you show, I would use face based walls ou curtain systems.
    Junior Member Henry's Avatar
    April 18, 2011
    Harderwijk Netherlands
    21
    06:58 PM
    solar panel
    It is in-place,
    can you use this?
    Attached Files Attached Files
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    11:58 AM
    Piotr, metal panels are already in your Materials Library under 'Steel" or 'Metal - Panel'.
    To control shape, size, scale, ...etc of your cut-outs, use 'Appearance' tab in the 'Materials Library' dialog box.
    p.j
    p.j is offline
    May 22, 2011
    3
    04:58 PM
    thanks guys, that helped me a lot I need to practice a little and I will get it
    August 20, 2011
    1
    09:28 PM
    about the Curtain Panel, Solar Protection
    Dear friends,
    I have the same problem and I'm in urgent need of how to make my Curtain system as a Solar Protection, like the tutorial as you mentioned in the previous comments.
    I will be thankful, if anyone guides through this problem.
    your friend,
    Asrarto
    April 9, 2012
    2
    04:58 PM
    There are different factors or issue regarding in protecting your solar panels. It could be from weather, lightning, fire or even in thief. For a big investment like this, we must protect it whatever reason it is.
    Last edited by mdradvies; April 9th, 2012 at 06:18 PM. Reason: removed inappropriate link
    July 29, 2012
    2
    12:58 AM
    Solar panel protection
    Quote Originally Posted by Henry View Post
    It is in-place,
    can you use this?
    Could u mention it to me how could u create a new curtain wall system with curtain panel : perforated metal p like in ur attachment file?
  1. Custom Curtain Wall Panels and Mullions:
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: June 9th, 2011, 04:26 PM
  2. Custom Curtain Panels
    By MikeMaloney in forum Architecture and General Revit Questions
    Last Post: January 9th, 2011, 03:09 PM
Tags for this Thread
