Donate Now Goal amount for this year: 3000 USD, Received: 2477 USD (83%)
Results 1 to 2 of 2
Thread: Adaptive Component Help
    March 9, 2011
    12
    02:13 AM
    So I am trying to create my first adaptive component and need some help. I basically want to create a spline that is through 4 points, the start and end points will be at different locations, hence the reason I am trying to use and adaptive component, but at each point I want the spline to go though a defined point. Like this.
    The problem is that when I load it into a project or mass I get this. I doesn't seem to go through the point. Even though they are locked together and work fine in the family.
    Any thoughts?
    Attached Thumbnails Attached Thumbnails Adaptive Component Help-adaptive-spline2.png   Adaptive Component Help-adaptive-spline.png
    Attached Files Attached Files
    Orlando, FL, USA | info@planta1.com
    2,806
    05:13 AM
    I don't know what the final goal is, but I hope this helps:
    Select the spline you have, and click on Dissolve. Select the two intermediate reference points, and click on Make Adaptive. Renumber the points, from 1 to 4. Then select all the points, and select "Spline through points". Now, if any of the points move, the spline will adjust to them.
  1. Repeating 3D Component?
    By Scott_CJDH in forum Architecture - Family Creation
    Last Post: April 22nd, 2011, 02:37 PM
  2. revit 2012 adaptive component
    By Geert in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 13th, 2011, 08:50 PM
  3. Family vs Adaptive Component
    Last Post: January 5th, 2011, 08:19 AM
  4. Detail Component
    Last Post: December 14th, 2010, 11:42 PM
  5. Detail Component
    By gdoherty0102 in forum Tutorials, Tips & Tricks
