Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree2Likes
Thread: Tensile membrane structure, with hole cut in top
  1. #11
    Orlando, FL, USA
    3,139
    02:10 PM
    Those seams are going to be there because the canopy is made of four faces. If we don't want to see them, they can be eliminated with invisible lines in a project.
  2. #12
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    788
    01:10 PM
    Yeah, I figured. I tried to do it in one continuous spline to have only one surface or at least smooth transition between spline segments. Didn’t work so well, great exercise though.
    How about splitting then (see pic)? I think it is because there is no common edge, isn’t it? In this tutorial Modeling a tensile fabric roof in Revit - Blogs - Planta1 Revit Online Consulting your common edge between surfaces is spline #3, so no separation occurs. Am I on the right track, or totally lost it?
    Attached Thumbnails Attached Thumbnails Tensile membrane structure, with hole cut in top-splitting.jpg
  3. #13
    Moderator gaby424's Avatar
    December 11, 2010
    911
    08:10 PM
    maybe you like this
    more 3dmax transition style as in post number 3.
    2013-08-12_0023 - gaby424's library
    Attached Thumbnails Attached Thumbnails Tensile membrane structure, with hole cut in top-tensile.png
    Attached Files Attached Files
    PijPiwo likes this.
  4. #14
    May 20, 2011
    Chicago, IL
    788
    01:10 PM
    Gaby, this is AWESOME! (I knew I was on the right track )
  5. #15
    Member Alfienoakes's Avatar
    January 4, 2011
    West Sussex
    218
    07:10 PM
    Wow. This was just the kind of debate I had hoped to spark..
    Thanks to all of you for these helpful inputs. I have posted where I am at, which is further than where I was last week..!
    What I would now like to do, is create something that doesn't have the "edges" now, so it looks like a one piece skin thats being pulled from above. I did try adding some more profiles, but as PrjPiwo mention, the faces start to pull away from each other. Alf, as usual your tutorials are great, and I have used the "tent" type structure as a great basis. Gaby, yours had the smoothness I am after, but I cant view 2014 files at the mo..
    I will have a look at this, but if anyone has any other thoughts, it would be great to hear. I will post any updates.
    Cheers
    Attached Thumbnails Attached Thumbnails Tensile membrane structure, with hole cut in top-canopy-06.jpg
  6. #16
    January 4, 2011
    West Sussex
    218
    07:10 PM
    OK.. This is about as far as I reckon I can go with this.
    Getting a lot of errors depending on which reference point I try an drag around, and how much I try and drag it now. The exact error is:
    Unable to create form element: self-intersecting or singular geometry would result.
    So obviously pulling something around I shouldn't be..........
    The original method that Alf suggested, gives me more flexibility, but some hard edges. This version gives me a more "organic" look, but less flexibility..
    Cheers
    Attached Thumbnails Attached Thumbnails Tensile membrane structure, with hole cut in top-canopy-08.jpg   Tensile membrane structure, with hole cut in top-canopy-07.jpg
  7. #17
    Orlando, FL, USA
    3,139
    02:10 PM
    The real tents have those seams, even more. I don´t see why the seams should be "removed" from the Revit family.
    Attached Thumbnails Attached Thumbnails Tensile membrane structure, with hole cut in top-8-30-2013-6-41-26-pm.jpg
  8. #18
    February 20, 2015
    1
    06:10 PM
    Hey everyone, I'm just starting to get used to Revit and I thought it would take me forever to make a tensile membrane.. WRONG! maybe this example is not the most complex one but I think it's very simple and practical to start with, and then one could add and play with reference points to get the desired shape?
    Anyways, here is the link to the tutorial that helped me get started: https://www.youtube.com/watch?v=ApW9J5gxf2w
  9. #19
    Member Andrew P's Avatar
    February 19, 2011
    364
    06:10 PM
    Because in many cases you want a continuous surface, especially when you want to ad a curtain wall pattern based on it.
    FrenchQuarters likes this.
  1. Tensile Roofs in Revit Architecture
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: December 3rd, 2012, 03:59 PM
  2. my 3D view doesn't show the hole image anymore??!!!!
    By sixingno1 in forum Architecture and General Revit Questions
    Last Post: November 30th, 2011, 07:46 AM
  3. can we make hole in toposurface just like floor ?
    Last Post: November 3rd, 2011, 06:15 PM
  4. How do you model tensile fabric sun shades?
    By GenreNomad in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 13th, 2011, 07:12 PM
  5. How to keynote Membrane Layer (0 thickness)
    By Sputnik in forum Architecture and General Revit Questions
    Last Post: February 18th, 2011, 11:06 AM
