Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By elton williams
Thread: I can't cut a solid from a void form. Please help!!!!
    September 1, 2012
    1
    02:38 AM
    Exclamation I can't cut a solid from a void form. Please help!!!!
    Hi everyone. Here is my issue. First, I was working in conceptual mass environment, not in In-Place. I first chose a horizontal reference plane, then created a solid using the rectangle tool (model line not reference line). Then, as usual, I selected the rectangle and clicked on Create Form- Solid form. I got a solid, ok...so far so good. Then I selected another horizontal reference plane right above the first one. Next, I drew another rectangle above, but not aligned to the first rectangle (I overlapped them). I then selected this second rectangle but instead of clicking on Solid form, I click on Void form. So I got the void form. So now I had these 2 objects, one solid and one void, overlapping both horizontally and vertically. Now, automatically the void creates, well... a void in the solid. That's not where I have a problem. The trouble begins when I actually want to cut the solid using the void form. I go to the Cut command above, and as directed, I select first the solid and then the void. Well...it's doesn't cut it. How do I know that? Because after this operation, when I click on the still remaining void form and delete it, the solid form remains unaffected- totally uncut as it was in the beginning. What is happening here? Please help!!!
    Please send your comments directly to my e-mail address: cpruszkowski@yahoo.com
    Thanks a lot everyone.
    Cezary
    Revit Guru marcello's Avatar
    April 30, 2011
    66
    11:38 PM
    please post the model and then we will take a look
    Gold Coast
    2,626
    04:38 PM
    Quote Originally Posted by cezaryp View Post
    ...when I click on the still remaining void form and delete it, the solid form remains unaffected- totally uncut as it was in the beginning...
    Cezary
    don't delete the void
    dzatto and Bross like this.
    Forum Addict Andres Franco's Avatar
    June 21, 2012
    Tours, France
    1,005
    08:38 AM
    Hi Cezary, maybe you must made the void touch the solid, otherwise the geometry don't works as one expected, you must: First: made the solid form, then select the face or segment in the solid you want to to use as reference plane, it depends, but I guess that way you can do it!!, best regards.
  1. Trouble convertning a certain form
    By sohn in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 11th, 2012, 08:16 PM
  2. Different Duct Shape/Form
    By bsouzab in forum MEP - General
    Last Post: April 18th, 2012, 02:12 PM
  3. Replies: 0
    Last Post: March 30th, 2012, 01:15 AM
  4. Replies: 0
    Last Post: December 12th, 2011, 05:45 PM
  5. question in substraction to create form ?
    Last Post: August 21st, 2011, 10:39 PM
