Donate Now Goal amount for this year: 3000 USD, Received: 1155 USD (39%)
Results 1 to 2 of 2
Thread: Request rights to a object
    March 12, 2012
    1
    10:59 PM
    Unhappy Request rights to a object
    Hey all
    I have just installed a Revit server 2012 central and local server.
    When I have 2 clients working on the same project, and one client requests a access to a object. it takes up to 2 minutes before the other client see the request.
    But when the first client locks a object it happens instant.
    Anyone here have an idea where to start troubleshooting?
    /Micki
    February 18, 2012
    12
    04:59 PM
    Quote Originally Posted by mickiolin View Post
    Hey all
    /Micki
    Hi Mickiolin,
    Run a tracert between both locations to your Revit Server IP. if you get any latency that is over 50ms along the route that could be a problem. High double digit ms is still workable but slightly annoying. Tripple digit latency will require evaluating your connection options.
    If you can get both sites on the same carrier as the Revit server that will help a little. If you continue to have problems post here with results from your tracert. There are also other options than Revit Server which are able to over come latency issues.
    Cheers,
    ~Scott
    Last edited by Munkholm; April 5th, 2012 at 09:52 PM. Reason: Removed inappropriate link
  1. Revit OpEd: Equal Rights for Specialty Equipment
    Last Post: January 13th, 2012, 05:17 AM
  2. RFo Support Request Shortcut
    By dzatto in forum Forum Suggestions and Feedback
    Last Post: November 3rd, 2011, 02:41 PM
  3. revit server model access rights
    By xiqx in forum Worksharing and Revit Server
    Last Post: November 1st, 2011, 10:08 PM
  4. Family request
    By Defiant1 in forum Structure - General Questions
    Last Post: May 4th, 2011, 10:08 PM
  5. Visitors rights ?
    By Munkholm in forum Forum Suggestions and Feedback
    Last Post: January 17th, 2011, 09:01 PM
