Donate Now Goal amount for this year: 3000 USD, Received: 2139 USD (71%)
Results 1 to 1 of 1
Like Tree1Likes
  • 1 Post By mark b
Thread: Auto Cavity End Closure and Continuous Cavities
    Moderator mark b's Avatar
    NSW Australia
    1,414
    12:49 PM
    Here is an old one but a good one.
    If you want a double brick wall with cavity to join on ends and intersecting walls to create a continious cavity automatically here is how.
    1.Duplicate or create a normal double brick wall (image1)
    2.Now you have to delete the "function" from the material that is outside
    the core boundry. (image2)
    There is a trick here Revit will not let you just select and delete the whole
    function line. You have to select just the function type ie. "finish" and delete
    and leave the number in brackets ie.(4) (image3) Then press OK then the function will
    be gone.
    Set wrapping at ends to "exterior" all done.
    Attached Thumbnails Attached Thumbnails Auto Cavity End Closure and Continuous Cavities-image3.jpg   Auto Cavity End Closure and Continuous Cavities-image-1.jpg   Auto Cavity End Closure and Continuous Cavities-image2.jpg
    Cyus likes this.
  1. Core Boundaries and Wall Closure ?
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: May 13th, 2011, 10:16 AM
  2. Beam Wall End Cutback
    By djnelson75 in forum Structure - General Questions
    Last Post: April 19th, 2011, 11:14 PM
  3. Dislocating n Auto Delete Slab
    By Yogesh in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 10:45 AM
  4. High End Cabinet Families
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2011, 12:44 AM
  5. Auto Log out?
    By eric.piotrowicz in forum Forum Suggestions and Feedback
    Last Post: December 12th, 2010, 12:12 PM
