Donate Now Goal amount for this year: 3000 USD, Received: 2050 USD (68%)
Results 1 to 5 of 5
Thread: Problems with revit 2012
    August 12, 2011
    1
    06:31 AM
    hello i'm new here, and i have a problem with the new version. i'm not sure if it's a problem with the new version or if it's a problem woth the instalation. i hope someone could help me.
    the thing is that i have downloaded revit architecture 2012 and it seems to be installed ok and well activated too. but when i start the program, it
    doesn't appear the elevations views that should appear for default. i don't know if it has something to do with this but also when i start the program it appears a window that says: the default template file you have specified does not exist.
    (hope it's a undestandable message english it's not my first language)
    United States
    1,132
    05:31 AM
    Is your INI correct?
    March 30, 2011
    Aarau, Switzerland
    105
    01:31 PM
    The template path is not correct. This may hapen sometimes. Just configure the correct value under options.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    11:31 AM
    Go to the program button (big R, top right), click it, select options in the bottom right corner. Go to the File Locations Tab and set a path to the default template file (has an .rte extension) for Revit projects.
    June 27, 2011
    19
    01:31 PM
    You most likely downloaded the exe instillation of Revit which tends to have not templates or families. Did it ask you to download content? If it did, this is definitely the case here. All you need to do is get hold of a disc or Iso of Revit and you should be able to uninstall and re-install. Just make sure that you go into the drop down in the instillation process of make sure that you have content pathed for you. The instillation initially says 3 or so gigs. It should say around 5 gigs in size.
  1. Decal problems
    By Hirvio in forum Rendering and Gallery
    Last Post: September 9th, 2015, 05:44 PM
  2. Pivoting Problems
    By Gabriel Black in forum MEP - Family Creation
    Last Post: September 9th, 2013, 10:00 AM
  3. Revit 2012 and 3ds Max 2012
    By JLRArch in forum Architecture and General Revit Questions
    Last Post: August 30th, 2011, 04:04 AM
  4. REVIT 2012 problems?
    By wbenatti in forum Architecture and General Revit Questions
    Last Post: June 25th, 2011, 01:08 PM
  5. Revit Server problems with large files
    By bimologist in forum Worksharing, Revit Server & C4R
    Last Post: February 1st, 2011, 07:19 PM
Tags for this Thread
