Donate Now Goal amount for this year: 3000 USD, Received: 1160 USD (39%)
Page 2 of 22 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 214
Like Tree56Likes
Thread: Revit Formulas for "everyday" usage
  1. #11
    New Member CJ Follmer's Avatar
    December 10, 2010
    St. Louis MO
    4
    12:22 AM
    Thanks a bunch for those. It will be a big help.
  2. #12
    Miami, FL, USA | info@planta1.com
    1,634
    01:22 AM
    There is little to add to this comprehensive list. However, I would like to add this:
    Range of Values
    Given the following parameters:
    user_value:
    min_value:
    max_value:
    actual_value:
    Specify a range of valid entries, with the min_value and max_value parameters; then, use the actual value if it is within the range; otherwise, use your minimum or maximum values.
    Code:
    actual_value = if (user_value < min_value, min_value, if (user_value > max_value, max_value, user_value))
    An example of this was applied in my solution for the last month´s thread about the corner piece challenge. See illustration.
    Attached Thumbnails Attached Thumbnails Revit Formulas for &quot;everyday&quot; usage-value-range.jpg
  3. #13
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    05:22 AM
    Great post Munk!
    One more comment on the if-statements when using combined with a yes/no-parameter:
    When using an if-statement for a yes/no-parameter the syntax is different.
    For instance:
    Door_width = 900 (length parameter)
    Building_Code OK (yes/no-parameter): Door_width>850
    There's no need to add the <if true>, <if false> part. It will actually give you an error.
    Also:
    When using formulas, revit is aware of the Units. So when you want this:
    Length1 = Length2*Length3 and they are all Length parameters, it will give you an error. Why? Because m x m = m2, which makes it an area parameter.
    You'll get the errror "incosistent units". The formula should be: (Length1*Length2)/1 to work.
  4. #14
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    2,547
    10:22 PM
    Additionaly:
    The division of 2 lengths will return and interger or number. Handy for array constraints or use in trigonometry calcs.
  5. #15
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    4,075
    12:22 AM
    Currently, <= and >= are not implemented. To express such a comparison, you can use a logical NOT. For example, a<=b can be entered as NOT(a>b)
    What if I need this statement, but with another parameter in front of it? For example:
    Lift Height (NOT<1'). It gives me errors saying the left paranthesis is unexpected. If I take out the parenthesis, I get errors saying Lift Height NOT is not a valid parameter.
  6. #16
    1,634
    01:22 AM
    I guess in the case of the lift it is better to use a range of minimum and maximum values. See reply # 12.
  7. #17
    Kingdom of Denmark
    3,977
    07:22 AM
    Dan, I´m assuming that "Lift Height" is a length parameter, and you don´t want that to be less than 1'
    If that´s the case, you should have a look at Alfredo´s post above (#12)
  8. #18
    dzatto's Avatar
    December 9, 2010
    4,075
    12:22 AM
    Well sort of. That formula may still work, but let me explain what I'm trying to do.
    The lift has ramps attached to it. When it is down, they are flat. When it is up the ends of them fall down with gravity so they are now angled. I used a Yes / no formula to control the visibility of which ramp configuration I need. The problem is that it's set to change at 1', and it does, but if the height is exactly 1' neither of them show! I really need a <= formula but I read in Munk's post that it's not possible.
    So, is this the correct formula?
  9. #19
    Kingdom of Denmark
    3,977
    07:22 AM
    Can you post the family...? not sure that I understand...
  10. #20
    Kingdom of Denmark
    3,977
    07:22 AM
    Ahh... think I know what you´re wanting to do... the NOT(a>b) doesn´t work with Yes/No (visibility) parameters, instead you can use a NOT as shown in the attached
    But... now that you figured the trig, maybe you should just add a Angle parameter to the Ramp, so it slides over the floor at an angle when the lift is raised from the floor ?
    Attached Thumbnails Attached Thumbnails Revit Formulas for &quot;everyday&quot; usage-ramp_not.jpg
LinkBacks (?)
  1. February 28th, 2012, 03:07 PM
  2. January 10th, 2012, 01:31 PM
  3. January 2nd, 2012, 06:57 PM
  4. December 2nd, 2011, 11:31 AM
  5. November 4th, 2011, 08:59 AM
  1. Fórmulas de Revit para el "uso diario"
    By Munkholm in forum Foro Español
    Last Post: June 7th, 2011, 11:43 AM
  2. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    By jh75 in forum Structure - General Questions
    Last Post: May 6th, 2011, 08:39 PM
  3. Revit 2011 - "Black rendering" with Non-English Win XP
    By Munkholm in forum Tutorials, Tips & Tricks
    Last Post: January 10th, 2011, 08:15 AM
  4. Replies: 2
    Last Post: January 7th, 2011, 06:19 PM
  5. Replies: 2
