Donate Now Goal amount for this year: 3000 USD, Received: 1130 USD (38%)
Page 11 of 22 FirstFirst ... 78910111213141521 ... LastLast
Results 101 to 110 of 214
Like Tree56Likes
Thread: Revit Formulas for "everyday" usage
  1. #101
    Member ikinks's Avatar
    March 10, 2011
    Netherlands, the eastern part
    114
    05:51 AM
    Why does Revit return a formula that contains an exponent of zero (^0) with an inconsistent units warning? The logical (and legible) result of i.e. 5^0 is 1, but somehow Revit can't cope with that particular exponent.
    Last edited by ikinks; October 19th, 2011 at 09:16 AM. Reason: doing the maths again, this time correct
  2. #102
    Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    261
    05:51 AM
    5^0=1
    1+1=2
    etc.
    Munkholm and JWR like this.
  3. #103
    May 23, 2011
    Netherlands
    261
    05:51 AM
    1m^3 = 1m³, 1m^2 = 1m², 1m^1 = 1m, 1m^0 = ??? I would think this gives a unitless number.
    Edit: it does not. Limit input to number values and you'll be fine.
    Edit2: doesn't even do that. looks like you need a workaround if you need an exponential parameter.
    value y would be 2^value x
    value y = if (value x=0, 1, 2^value x)
    Edit 3: probably pending
    O, and edited Revit Formulas for "everyday" usage, the post that was meant to go down in history as my bestest post ever. So much for everlasting glory, tnx gaby424.
  4. #104
    March 10, 2011
    114
    05:51 AM
    Quote Originally Posted by ekkonap View Post
    Well, I was fiddling with some formulas, trying to convert a binary code into a unique decimal number and for consistencies sake I wish the ^0 exponent works.
    Binary code (8 bit in this case): 10110101
    Breakdown:
    A 1
    B 0
    C 1
    D 1
    E 0
    F 1
    G 0
    H 1
    Formula:
    (A*2^7) + (B*2^6) + (C*2^5) + (D*2^4) + (E*2^3) + (F*2^2) + (G*2^1) + (H*2^0) =
    1*128 + 0*64 + 1*32 + 1*16 + 0*8 + 1*4 + 0*2 + 1*1 =
    181
    Note that (H*2^0) doesn't work in Revit. Use (H*1) instead.
    The number of the highest exponent should be the number of bits minus 1. Every next bit the exponent decreases by one.
  5. #105
    Kingdom of Denmark
    3,975
    05:51 AM
    Circular Segments Formulas
    Ever needed to calculate circular segments? Made this one earlier, to get the radial arrays right in this family, but figured that it might come in handy for something else, so saved it out at a early stage.
    Attached Thumbnails Attached Thumbnails Revit Formulas for "everyday" usage-circular-segment.jpg
    Attached Files Attached Files
  6. #106
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    2,539
    08:51 PM
    Quote Originally Posted by Munkholm View Post
    I knew i should of paid more attention in math class. Damnit!!!
  7. #107
    January 11, 2011
    UK
    12
    03:51 AM
    hi im have a made a family with several tick options,
    P1 to P8
    I would like to add a formula that is P1 is ticked then P2,P3 etc to P8 cannot be..is this possible?
    i tried NOT (P2) but cannot add anymore
  8. #108
    January 11, 2011
    UK
    12
    03:51 AM
    adding, so that you can only tick one box.
    ie If =P8 you cannot put a tick in p1,p2,p3 etc
  9. #109
    Member Joshua Kohl's Avatar
    Behlehem, PA
    79
    11:51 PM
    Quote Originally Posted by James View Post
    You might want to try a variation of what Steve Stafford describes in his blog post Revit OpEd: Make Up My Mind
  10. #110
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    03:51 AM
    not without some major formula work and extra parameters no. Keep asking yourself this question: what if I check off this one parameter? Is the action that needs to follow clear for Revit? Is there only one course of action? If not, it won't work.
    The only way I can see this to happen is if you add a integer parameter (either manual or based on the outcome of a formula). Now reference the P1 to P8 parameters to the integer (for instance, formula for P1 would be: integer (place parameter name) = 1. Formula for P2 would be: integer​ = 2, and so on)
LinkBacks (?)
  1. February 28th, 2012, 03:07 PM
  2. January 10th, 2012, 01:31 PM
  3. January 2nd, 2012, 06:57 PM
  4. December 2nd, 2011, 11:31 AM
  5. November 4th, 2011, 08:59 AM
  1. Fórmulas de Revit para el "uso diario"
    By Munkholm in forum Foro Español
    Last Post: June 7th, 2011, 11:43 AM
  2. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    By jh75 in forum Structure - General Questions
    Last Post: May 6th, 2011, 08:39 PM
  3. Revit 2011 - "Black rendering" with Non-English Win XP
    By Munkholm in forum Tutorials, Tips & Tricks
    Last Post: January 10th, 2011, 08:15 AM
  4. Replies: 2
    Last Post: January 7th, 2011, 06:19 PM
  5. Replies: 2
