Donate Now Goal amount for this year: 3000 USD, Received: 1130 USD (38%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: List every Family and its parameters in a document
    Junior Member KRedman's Avatar
    Lafayette, IN
    15
    09:22 PM
    I'm able to report all parameter types only if the family document (rfa) is open itself, but I'm not so clear on how to do this when a project file is open. I've read in a couple of different places that families can be opened in the background and modified, but I can't figure it out.
    Any help is greatly appreciated!
    Nantes, France
    1,195
    04:22 AM
    I can't really find out what you mean, but the following links (you may know them already)
    may help you.....
    Using Google translation, you will find API to copy or filter families.
    https://sites.google.com/site/kartsup/
    http://kartautodeskuser.blogspot.com/
    cheers
    Member krispy5's Avatar
    December 21, 2010
    62
    01:22 PM
    are you getting only instance or type parameters?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    02:22 AM
    Quote Originally Posted by KRedman View Post
    I am not really sure what you mean. If you create a family you use parameters. Those are Instance Parameters (in the Properties Dialogue Box when you select it) or Type Parameters (in the Type Properties). The Parameter Category depends on the kind of parameter and cannot be modified.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    02:22 AM
    Kingdom of Denmark
    3,977
    04:22 AM
    Quote Originally Posted by mdradvies View Post
    Hey pssstttt.... Martjin, this is the API forum...
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    02:22 AM
    Quote Originally Posted by Munkholm View Post
    ahhh, now I now what he means...
    Sorry, my current crappy internet connection forces me to read (and type) real quick otherwise I lose my connection.
    So, I'll just get out of the way done and return to work...
    Member KiwiCodes's Avatar
    278
    02:22 PM
    Hey Kenny. Did you get this sorted? I have just seen your post. If you need any help give me a yell.
    Cheers
    Phillip
    Lafayette, IN
    15
    09:22 PM
    Quote Originally Posted by KiwiCodes View Post
    Cheers
    Phillip
    Thanks Phillip- I've been working on some other non-Revit projects the last week and haven't had any time to work on it. I thought I had an idea on how to do it. You showed me how to open an .rfa family file by accessing its physical location, but I'm unclear on how to do that from a family in the project.
    278
    02:22 PM
    I'm pretty sure you can open a family file like that as well. Another options is to start a new transaction, loadin the family to the current project, do what you have to do to the family , Save the family?? and then rollback the transaction if you don't want that family loaded.
    Cheers
    Phillip
  1. Family Parameters : Void
    By Scott Deslippe in forum Architecture - Family Creation
    Last Post: May 5th, 2011, 06:12 PM
  2. [All Verticals] - System Family - Spot Elevation Parameters
    By Alex Cunningham in forum 2011 Archive
    Last Post: March 16th, 2011, 02:33 AM
  3. family and shared parameters
    By jbenoit44 in forum Architecture - Family Creation
    Last Post: March 2nd, 2011, 12:24 PM
  4. How to Order Revit Family Parameters
    By Scott Hopkins in forum Tutorials, Tips & Tricks
    Last Post: January 2nd, 2011, 11:50 AM
  5. Family With Multiple Parameters ( excel style format)
    By JCM in forum Architecture - Family Creation
    Last Post: December 28th, 2010, 03:51 PM
