Donate Now Goal amount for this year: 3000 USD, Received: 904 USD (30%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: Too thick lines in editor, how to fix?
    September 21, 2011
    Paris
    6
    02:34 PM
    Hi everyone, I'm glad to post today from France my first question!
    When editing a contour for a roof or to create an extrusion in a family, I get very thick pink lines. They are so thick that it's very difficult to adjust the lines, I really don't see what I do. The more I zoom, the bigger they get!!!
    Is there any parameter to adjust in order to get very thin lines while editing?
    Thanks a lot.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    12:34 PM
    Hi Eric, welcome to the forum...
    Go to Manage > Additional Settings > Lineweights to check which thickness will be OK, and which number references to it (probably 1 or 2 will be fine)
    Then go to Manage > Additional Settings > Line Styles and look for the line type <Sketch>. Set this to the appropriate value.
    Eric likes this.
    December 21, 2010
    C.LONDON
    3,264
    01:34 PM
    But in the meantime, simply turn of line thickness by entering the keyboard shortcut :
    TL
    -which is only a visual change (like Lineweight in Autocad) - Martijn's explains how to make the change global and permanent
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    12:34 PM
    I don't like TL since your screen can seriously divert from the plot settings... Which causes some serious confusion and
    December 21, 2010
    C.LONDON
    3,264
    01:34 PM
    Quote Originally Posted by mdradvies View Post
    I know what you mean - and it would be nice never to have to use TL but sometimes it's just nicer to work without thicknesses - and since Eric's in sketch mode print-related disparity isn't really an issue here.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    12:34 PM
    True,
    What I meant to say was: I've had myself forget to turn the TL back off so many times I just took the time to do the permanent thing once in my template and have banned the useage of TL all together. But hey, YMMV...
    September 21, 2011
    Paris
    6
    02:34 PM
    Fine, but ...
    Thanks guys, I set 1 for the <esquisse> line (ie <sketch>) and it's quite better. But if I make a big zoom, the lines are still very big compared to those of the editor which remain at 1 pixel.
    I find it very fustrating since it's a working line, not a render line, it will never appear in the project, it's just a guide for me to tel Revit where I want the profile, or whatever. Unfortunately, it seems I can't create a 0 size line!
    I wonder how people use this feature in the family editor to create very small details where the <sketch> line is 10 times bigger that the detail and covering it. Compared with what i'm used to in Illustrator or other tools like this, it's very surprising.
    September 21, 2011
    Paris
    6
    02:34 PM
    I would add that the plane reference lines, which appear in green, remain 1 px thick at any kind of zoom. One could expect to get the same behavior with <sketch> lines that serve the same purpose. Any idea how to do it ?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,173
    07:34 AM
    I toggle to Thin Lines myself. Sometimes, I design in TL mode. I don't have any issues not seeing the plot settings. And, if I need to see them, its a few keystrokes away.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    12:34 PM
    Sketch Lines are for some reason View Scale dependant. Or not and everything else is... Either way, it's indeed a bug. I don't think you can do anything about this besides TL.
  1. group editor background color
    By elton williams in forum Architecture and General Revit Questions
    Last Post: April 13th, 2015, 05:16 PM
  2. Material Editor slow as all get out sometimes... anyone else?
    By JeffreyMcGrew in forum Architecture and General Revit Questions
    Last Post: March 28th, 2012, 11:34 PM
  3. How to print that all lines would be thick lines?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: July 14th, 2011, 08:07 AM
  4. Material Editor Crash
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: May 25th, 2011, 11:32 AM
Tags for this Thread
