Donate Now Goal amount for this year: 3000 USD, Received: 1448 USD (48%)
Results 1 to 5 of 5
Thread: retrieve the slab thickness via a parameter ?
    March 21, 2011
    Brisbane
    201
    02:04 AM
    Is it possible to retrieve the slab thickness via a parameter to then schedule it?
    Thanks,
    J
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    04:04 PM
    Not to my knowledge. The profile cannot be set up using SP's and I don't see any parameter nesting possibilities in the Project.
    Orlando, FL, USA | [email protected]
    2,788
    12:04 PM
    There is no direct "Thickness" parameter for floors. There are at least 2 alternatives:
    1) Create a project parameter (type, length) that applies to floors. Name it as "Thickness". Select your floor, and, in Edit Type > Properties dialog, enter the value for the thickness of that type of floor. Then, include this parameter in your schedules. Just keep in mind that this value was entered manually. It won't update by itself if you change the thickness of the slab.
    2) "Thickness" is not an available field in the Floors schedule. But "Volume" and "Area" are available. If, only if, the geometry of your floor is simple and of constant thickness, you could create a calculated value (length) named as "Thickness" and make it equal to = Volume / Area.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    04:04 PM
    But the volume/area thing won't work with a slab. If the slab is counted at all, it will be leveled out across the entire floor surface...
    EDIT: Never mind, I keep forgetting that a slab is a structural floor and a Slab Edge is the thick part... Yes, this would work.
    Nantes, France
    1,377
    05:04 PM
    I use type comment (changes when type changes). you may also try Parts for the floors, you got the thickness if I remember well.
  1. Revit SDK 2012 Retrieve Filtered Elements example
    By Nelson in forum Third party Add-Ins, API and R&D
    Last Post: April 28th, 2011, 01:18 PM
  2. Changing wall thickness , Cannot extend layers
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 27th, 2011, 08:03 PM
  3. Waffle Slab
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 02:13 PM
  4. How to keynote Membrane Layer (0 thickness)
    By Sputnik in forum Architecture and General Revit Questions
    Last Post: February 18th, 2011, 11:06 AM
  5. Convert Project Parameter to Shared Parameter
    By Rustle in forum Architecture and General Revit Questions
    Last Post: January 5th, 2011, 07:35 AM
