Results 1 to 8 of 8
Thread: Interior / exterior / foundation / retaining / soffit / core-shaft
    March 18, 2013
    11
    12:25 AM
    Hello again forum
    As the title says, i have some questions about the type properties of the walls that one have to change if the wall is interior, exterior, retaining, etc.
    In advance, many thanks for your help, I really REALLY apreciate it, you are great!
    Interior / exterior / foundation / retaining / soffit / core-shaft-interior-exterior-foundation-etc.jpg
    1. Do I have to select each wall and choose one of that options?
    2. For what is good that? Only for filters? isnt it better that those options be as an "instance" options and dont a "type" option?
    3. When do I have to use it and when not?
    4. Please explain me what is a CORE SHAFT WALL??? are they the structural walls of the elevators?? (I am an architect from Per˙, so here is other language, but the translator cant explain me what is a core shaft wall)
    5. When do I have to use the wall type propertie foundation wall?? isn't better to use the "structural foundation wall" buton?
    and for last
    6. the instance property "structural usage", is that really necesary to use? or only for analityc use?
    Interior / exterior / foundation / retaining / soffit / core-shaft-bearing-shear-structural-combined.jpg
    I know that are a lot of questions... so I will be really gratefull.
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    741
    11:25 PM
    1. No, this is a type property, so all instances of this wall type will retain that "function"
    2. Filters, schedules, anything the information can be used in. Also, when exporting to gbXML the different functions produce different results. So if you don't want to be thought of as silly 40 years down the road when an intern architect has to export your as-built model for some renovations and needs a gbXML file, then you want to set these correct.
    3. Always. >_>
    4. My understanding with my wee non graduate brain is that core shaft walls are constructed differently from partition walls due to the nature of needing to be able to sheath the side of the wall that is in a shaft opening. This would be difficult to do in a 10 story elevator shaft. See if this document helps any (sorry it's in engrish) http://www.usg.com/rc/system-catalog...g-en-SA926.pdf
    5. Foundation walls behave differently with their top and bottom constraints from non foundation wall types. They rely on depth, instead of height. The only difference between using the wall tool and the structural wall tool is that by default when you place a foundation wall with the structural wall tool, the "Enable Analytical Model" is checked. (correct me if I'm wrong)
    6. See above. This parameter is set by default to Non-bearing when you use the architectural wall tool, and to Bearing by default when you use the structural wall tool.. well, that's not technically correct. Technically it is set to the default structural usage value, which I believe is defined somewhere in the structural settings in Revit.
    Hope that clears some things up.
    March 18, 2013
    11
    12:25 AM
    Thanks Revittotd that have been very helpfull
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    4,652
    12:25 AM
    Quote Originally Posted by revittotd View Post
    I've always wondered why Revit called them Core Shaft Wall and not just Shaft Wall.
    But yes, shaft walls (trash chute, linen chute, HVAC chase) must have sheathing on both sides of the stud in order to be rated (UL U415 or similar.) I've not seen an elevator shaft constructed this way but we rarely work on buildings that are more than three or four stories (and use masonry more often than not.) The U415 mentioned above is a 1" shaft liner, a metal C-H stud and a 5/8" type X GWB and gives 1-4 hours of protection.
    March 18, 2013
    11
    12:25 AM
    So the shaft wall is really a cover to protect from fire... uhmmm really revit was built for the USA construction system, here, the walls of the shafts are like any other wall, maked with masonry, so I asume I dont make them shaft walls
    Coeur d Alene, ID
    3,555
    09:25 PM
    I'm not sure as I never have looked....but I wonder if a wall is selected as a core shaft it may show up differently on a MEP view? Kinda like a stud wall needs to be marked as structural to show on a Structural View...
    April 21, 2011
    Oklahoma
    741
    11:25 PM
    Maybe this will clear up what you are looking for:
    When you export analytical surfaces to gbXML, the Function type parameter affects walls, floors, and building pads as follows.
    Interior surfaces
    If its function is Interior or Core Shaft, a wall is displayed as an interior surface, regardless of the number of adjacent spaces.
    from: Function of Walls, Floors, and Building Pads - WikiHelp
    Autodesk TheViking's Avatar
    Lexington, MA
    153
    12:25 AM
    The difference between the "Wall" tool and the "Structural Wall" tool is the Structural parameter value. It is set to checked when the Structural Wall tool is used. The analytical model is not required for a wall to be considered Structural.
    Erik
  1. how do you isolate exterior or interior?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: November 5th, 2012, 09:07 PM
  2. How to track core, interior side and exterior side in a wall
    By cyberjuls in forum Architecture - Family Creation
    Last Post: June 21st, 2012, 11:05 AM
  3. Show Off Your Interior / Exterior Spaces
    By dzatto in forum Out There
    Last Post: May 4th, 2011, 04:13 PM
  4. Shaft opening
    By madsagger in forum Architecture and General Revit Questions
    Last Post: April 14th, 2011, 03:31 PM
Tags for this Thread
