Donate Now Goal amount for this year: 3000 USD, Received: 980 USD (33%)
Results 1 to 6 of 6
Thread: diagrid family
    March 22, 2012
    2
    08:43 AM
    diagrid family
    So i'm currently working on a steel diagrid frame, to support a 8 storey building. One of the facades is sloping inward making the area smaller as the elevation goes up. this result in two triangluar sides with incomplete surface grids. My pattern is made from "Metric Curtain Panel Pattern Based" with a triangular(Flat) base grid.
    Now, i want the surface pattern to fill the whole grid, so I can join the triangular sides with the sloping backside.
    Below: the first picture displays the building, and the secound one off walls with the border tile set to "empty" the third with "parcial"
    diagrid family-capture3.pngdiagrid family-capture2.pngdiagrid family-capture.png
    in other words, I want the pattern to be "cut" outside the grid surface. I have tested with different parameters and pattern familys, but always with the same result. How do i accomplish this?
    Member Ben-May's Avatar
    December 8, 2010
    Melbourne,Oz
    295
    04:43 PM
    Not sure this can be done with your current method
    I would make a smaller panel family and infill the missing segment
    You can divide by reference plane to get the angle
    Nantes, France
    1,191
    08:43 AM
    This should be made with adaptive component. Have look in the forum, I'll be back later. but you should succeed with AC.
    UKN
    UKN is offline
    Junior Member UKN's Avatar
    February 16, 2011
    Copenhagen, Denmark
    28
    08:43 AM
    You might want to check this video out: Vasari Advanced Skills - Adaptive Component part 1/2 - YouTube
    Good luck :-)
    December 8, 2010
    Melbourne,Oz
    295
    04:43 PM
    Quote Originally Posted by jbenoit44 View Post
    Looking at the OP I figured he was already using AC's??
    March 22, 2012
    2
    08:43 AM
    I have been away from my computer during the weekend, I have tried making some AC. But I'm still quite new to the family concept. But thank for the reply. I'll try AC once again, mhopefully with more luck than last time.
  1. Live Session - Family Creation Series |#2-Family Planning
    By revittotd in forum Live Sessions - Archive
    Last Post: March 21st, 2012, 08:01 PM
  2. Family Type Parameters and "Export Family Types" functionality...
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: September 7th, 2011, 07:05 AM
