Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Results 1 to 10 of 10
Thread: Slab Parameter
    August 8, 2011
    19
    04:18 PM
    Slab Parameter
    good day,
    Thus anyone know how to link the Default Thickness to Slab_D......Slab_D is a shared parameter that i created...Please find the attach file for reference..
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    12:18 PM
    As far as I know this is not possible. Default thickness is an ootb parameter which doesn't show up in the Profile Family. In the project environment you can't ty both together...
    Member AHutchinson's Avatar
    September 19, 2011
    Spokane, WA
    230
    05:18 AM
    Could Slab_D be a reporting parameter? I don't exactly understand them, but they can work for lengths.
    August 8, 2011
    19
    04:18 PM
    Slab_D is not possible to be a reporting parameter its because the slab is a system family... reporting parameter will work only in non-system family such as beam, column, etc...
    what im trying to obtain here is i want to use the Slab_D as my slab tag for detailing purposes.. For example i want the slab tag to be 400.. its easy to get the slab tag 400 by renaming the type name to 400...but i dont want to do that.. because we have a standard for type name in particular for slab..we can also place a type parameter such as i do but it is not automatically change if you change the slab thickness......
    Nantes, France
    1,377
    02:18 PM
    Hi Christian, you should try this family....hope you like it. it reports the slab thickness. just place it on a floor.
    credits to: Revitez!: Utiliser les paramètres de rapport pour coter l'épaisseur d'une dalle dans un plan d'étage
    Attached Files Attached Files
    August 8, 2011
    19
    04:18 PM
    wow...this is great!!!...i have to explore this on maybe i will come up with ah real floor tag..
    thanks julien....
    September 28, 2011
    1
    01:18 PM
    Hello Julien ,
    Please, could you send a 2011 revit version of this family?
    Thanks,
    Michel
    Nantes, France
    1,377
    02:18 PM
    Hi Michel,
    Welcome to RFO.
    Saddly I no longer have rst 2011 installed, so I will encourage you to read carefully the blog linked above, even with google translate.
    The main concept is to add a report parameter (A) to the host in a generic floor-base family. Then you add a shared parameter, and link it to A writing SP=A. Now SP reports the value of A, the floor thickness in fact.
    You need now a generic annotation, reporting the shared parameter SP.
    Nest the anno to the family, and link it to SP. Done.
    It should take less than 10'. And the result worth it.
    August 2, 2011
    150
    08:18 PM
    Dear Julien,
    I tried to read the blog but it's not in English;so i don't understand what it means.
    Furthermore, I can't do as what you instrusted in above.
    Could you please tell me in English Version?
    October 22, 2011
    85
    08:18 PM
    Quote Originally Posted by jbenoit44 View Post
    hi jbenoit44, can you give us a quick guide on how you did this family? pls. thanks.
  1. retrieve the slab thickness via a parameter ?
    By jh75 in forum Structure - General Questions
    Last Post: May 26th, 2011, 04:44 AM
  2. Slab Edges!!!!
    By Alex Cunningham in forum Structure - General Questions
    Last Post: May 25th, 2011, 11:01 PM
  3. Creating floor slab
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 06:01 PM
  4. Waffle Slab
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 02:13 PM
  5. Convert Project Parameter to Shared Parameter
    By Rustle in forum Architecture and General Revit Questions
    Last Post: January 5th, 2011, 07:35 AM
