Just wondering what others are doing in this situation ie mezzanine or floors with steps ups /downs. Not sure on correct presentation methods, view range becomes a head@#%$... what's the best practice here? Cheers.
MONUMETRIC Video mmt-volt
Floors with different levels
Well, if it stays under the default View Range Cut Plane (1200mm in my plan views) it will be modelled as a reference to the level my view is in. So a floor on Level 1 with two 200mm steppings will have all those steppings and the heightened floor modelled in relation to Level 1. If it's 6+ steps, the heightened floor will be on a separate level.
That might not be correct building-wise but saves me a lot of grief dealing with plan regions and stuff.Martijn de Riet
Professional Revit Consultant | Revit API Developer
MdR Advies
Planta1 Revit Online Consulting -
option available on:
[x] Revit Architecture [X] Revit MEP [X] Revit Structure
For create just one or more area (zone) with different "view range" on the same main view :
1) Show the main view plan and make correct View Range as you want (the main view range of view).
2) Ribbon revit --> View --> Plan Views, select Plan Region. Place zone with line tools on your plan view, Valid (green arrow)
3) on the properties (or ribbon revit [Modify | Plan Region] ) select: View Range. Modify as you want (its the view range only for the area as you draw)
4) make another plan region if you want (but no overlapping region )
5) done..
Tips:
Modify line region area type :
Ribbon Revit --> Manage --> Object Styles -- > Annotation Object --> Plan Region --> change line Weight, line Color, line Pattern
Hide, unhide line region area:
[V]+[G] --> Annotation Catégories --> Plan region --> Uncheck for hide line , check for visible line area.
If area line is hide, go (in your main view) Reveal Hidden Element (icon: electric bulb, near eyeglass) for see hidden line.Bien piètre l'élève qui, un jour ne dépasse pas son maîtreComment
Options:
Create our own levels and views specific to just those areas (Maybe have the Architect place new levels for coordination alert monitoring)
Force the view to see a view from a linked model.
Trying to get the link to look correct and our own modeled elements to show what is in that levels space...uhhh. I know what you're saying. In addition to this issue are spaces. I have issues with spaces 100% of the time with interstitial levels and mezzanines. I think it has to do with HOW the Architect setup his levels and rooms.
Too bad plan regions don't work for MEP."Keeping my view range hopeful"Comment
I've got a Plan Region that's not behaving as I would expect.
The model has a few upper cabinets that are lower than usual.
Because they...March 9, 2018, 05:02 PM -
how to create partial view range?
I was told that in revit 2013 we are able to create a box and change the veiw range ( different than the whole...-
Channel: Structure - General Questions
October 22, 2012, 05:16 PM -
Hi! I am a very new Revit user. I have set up several levels in my Revit model of a house, and I am having a problem with them. It seems like they...January 4, 2013, 05:49 PM
Can objects overlapping a Plan Region boundary definition be clipped away?
We can define and use Plan Regions to change the View Range...November 4, 2016, 02:02 AM -
In Revit 2019, is there a way to "show in view?" Like the opposite of "hide in view?"
I have a plan that has a steeply...August 15, 2019, 02:43 PM
MONUMETRIC Anchor B sticky footer - 7ba6
