Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Results 1 to 4 of 4
Thread: adding key notes in Revit MEP
    January 7, 2012
    8
    08:35 PM
    what is the most productive way of adding key notes to the sheets in Revit MEP?
    Member Jrobker's Avatar
    December 9, 2010
    Salt Lake
    174
    09:35 PM
    I think this is the first time I have heard the words "productive" and "Revit MEP" in the same sentence...huh.
    I would suggest using the TXT file, and than keynoting by sheet or project.
    Any other option takes the I out of BIM.
    New Member lfried's Avatar
    April 11, 2011
    Visalia, CA
    2
    08:35 PM
    We use a generic annotation symbol that populates a note block. It's pretty efficient when used correctly.
    Mr. Revit OpEd
    2,157
    08:35 PM
    Research the "rich man's" key note features. The "User" key note is your friend for "vaguely" using key notes to identify a wide range of things. It's all based on the same source file so they are very consistent. You can have a single all encompasing sheet with keynotes or provide keynotes legends on each sheet. Some careful filtering can provide just what you actually placed on each sheet or just let people look them up on the master sheets.
    If you go this route you'll want Steve Faust's Keynote Mgr tool (Revolution Design), it makes the editing of the files much more "fun"!
    Fwiw, I refer to the Note block keynoting approach the "poor man's" key note. I do so because it's based on scheduling the occurrences of unrelated annotation symbols, you can't filter by sheet, and you have to have a unique type for each kind of "note". It's different (maybe less slightly) "overhead" but has some limitations too.
  1. Replies: 0
    Last Post: December 14th, 2011, 12:45 AM
  2. Standard Notes - Transferring Between Revit Projects
    By MartinGT in forum Architecture and General Revit Questions
    Last Post: December 8th, 2011, 03:19 PM
  3. How to link properly ACAD notes to Revit to get actual scale
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: September 29th, 2011, 02:09 AM
  4. Replies: 0
    Last Post: September 23rd, 2011, 05:24 PM
  5. Notes directly on Sheets
    Last Post: February 10th, 2011, 03:13 PM
