Donate Now Goal amount for this year: 3000 USD, Received: 2100 USD (70%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Mep reflected ceiling plan?
    August 22, 2013
    6
    05:42 PM
    Okay so heres a little brain twister I came into today. I am electrical when I went into my MEP reflected ceiling plan to try and place a lighting fixture on face it wont let me, me and our BIM Guru search through looking for ceilings and everything the ceilings are there to host but it will not let you. We found out that if you turn off the lighting fixtures in revit links from the architectural model, surprise surprise it allows you to host stuff to the face. I have never seen this before, has anyone else had this trouble before or know what the reason for it is????? your help would be greatly appreciated!
    July 24, 2013
    33
    04:42 AM
    Sometimes the Architects revit model lights are ceiling hosted, which kind of means they will "cut" a hole in the ceiling. It could be that?
    I can't remember how to stop that from happening though. I normally ask the architects not to model lights or just link in ours
    August 22, 2013
    6
    05:42 PM
    Thank you for that I have seen that before but unfortunately it is not that if the lights were "cutting" the ceiling it wouldn't let you put a luminaire just where the light fixture is but this is we cant place anywhere on the grid unless the lights are turned off. mechanicals and technologies models are doing the same thing nothing can be hosted.
    Member Andres Franco's Avatar
    June 21, 2012
    Lille, France
    298
    12:42 PM
    Quote Originally Posted by shifter22 View Post
    can you post a part of your model?
    August 22, 2013
    6
    05:42 PM
    I can not. Don't want to get into trouble with the company
    August 22, 2013
    6
    05:42 PM
    weird thing is I took out part of the arch ceiling made my own project with that ceiling and it lets me host to it and also we had the model change hands through one arch firm to a new one could that have done something to the model??
    June 21, 2012
    Lille, France
    298
    12:42 PM
    Are you trying to use the copy monitor option to creates your own levels based on the levels of your architectural model?, this way you can create you own work planes, so, in your own levels and work planes you can put those objects you need.
    August 22, 2013
    6
    05:42 PM
    So we got it figured out looks like the firm started doing renderings for their model and their light sources when turned on are huge! you can place something anywhere that the light sources are not.
    March 20, 2012
    Austin, Texas
    224
    12:42 PM
    Ah I wonder if this is related to a problem I found recently. Apparently if the light source is set to something other than a photometric web, it will count as a clash as well. Maybe it's seeing the light source as an actual object.
    August 22, 2013
    6
    05:42 PM
    Quote Originally Posted by Aaronb View Post
    that is what it seems like
  1. How do I use Reflected Ceiling Plans (RCP) in Revit to create a Lighting Plan?
    By j2mattones in forum Architecture and General Revit Questions
    Last Post: April 7th, 2014, 12:17 AM
  2. Placing lights in reflected ceiling plan
    By byork in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2012, 05:10 PM
  3. Nothing visible in Reflected Ceiling Plan
    By Justin McAllister in forum MEP - General
    Last Post: May 13th, 2012, 07:19 AM
  4. Reflected Ceiling Plan Surface Pattern
    Last Post: March 20th, 2012, 05:20 PM
  5. Reflected Ceiling not showing in underlay
    By RabbitHole in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 01:18 PM
