Donate Now Goal amount for this year: 3000 USD, Received: 1130 USD (38%)
Results 1 to 10 of 10
Thread: How do I get pendant lights to hang from the ceiling that appear not to be there?
    May 2, 2011
    Jansville, WI
    1
    04:27 PM
    I received a Revit model from the GC and am trying to put the electrical in place. I must say it has been very trying! I am trying to place a "pendant light -linear 2 lamp" 9 foot AFF. I cannot seem to find a ceiling in the Arch. model and the RCP shows an open ceiling. I tried to place above the floor, but it places the fixture upside down. Any help would be greatly appriecated.
    Thanks, Dicky-D
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    09:27 PM
    Could you post the family and/or projectfile? It's kind of hard to determine the problem, could be anything.
    1,241
    04:27 PM
    Change it to a face-based family from a ceiling-hosted family--this way you can have it attach to something other than the "missing ceiling".
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    4,060
    04:27 PM
    Is there a quick way to change the host of a family?
    If it's made of a nested generic model, then hosted into a family it's easy. But what if it's modeled in the hosted template? I've been trying to copy and paste it into the new type of hosted template. It's hit and miss.
    Member Jrobker's Avatar
    December 9, 2010
    Salt Lake
    107
    03:27 PM
    No quick way.
    There is NO quick way to do anything MEP in Revit.
    Keep in mind when Copy clipping into another project within Revit you must have both files open.
    Copy clipping multiple nested familes will not work.
    dzatto's Avatar
    December 9, 2010
    4,060
    04:27 PM
    Well, at least I know I'm doing it the only way it can be done. I hate doing something for a year, just to find out there's an easier way.
    Junior Member ELaforge's Avatar
    December 9, 2010
    9
    05:27 PM
    As mdradvies said "could be anything" my first thought would be to add reference planes at the heights that the ceilings are supposed to be and you will be able to use a face based light fixture hosted to the reference plane.
    As far as the fixture being upside down the issue could be that it was modeled that way in the family editor. For whatever reason when creating face based light fixture families the geometry for the fixture must be modeled upside down in order for it to be right side up when loaded into a project.........Makes A LOT of sense NO!!????
    Junior Member mog505's Avatar
    June 1, 2011
    United Kingdom
    34
    09:27 PM
    If the family is ceiling hosted, can you not host it onto the slab in the meantime and then offset the distance of the ceiling plenum?
    3,294
    04:27 PM
    Its not ceiling hosted if its letting him put it on the floor, upside down. That says its Work Plane Based (unhosted) or Face Based, and hes just placing it incorrectly. If its an open ceiling, make a reference plane at 9' AFF and Name it "9ft aff". Set that as your work plane, go to an RCP, and place it, using the "place on Work Plane" option.
    RME is plenty fast, if you know how to use it correctly.
    Member Ning Zhou's Avatar
    July 20, 2011
    311
    02:27 PM
    make sure that ref plane is drawn in reverse order to avoid upside-down issue, just curious if there's a way to "flip" existing ref plane?
  1. Ceiling
    By shiner79 in forum Architecture and General Revit Questions
    Last Post: May 25th, 2011, 06:51 PM
  2. Recessed Ceiling
    By dlggnation in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2011, 06:24 AM
  3. Lights on a sloped ceiling
    By Topdraw in forum Architecture and General Revit Questions
    Last Post: May 18th, 2011, 02:31 PM
  4. Ceiling help
    Last Post: May 3rd, 2011, 10:27 AM
  5. HEEEELP!!!!! Underlay+Ceiling
    By RabbitHole in forum Architecture and General Revit Questions
    Last Post: January 11th, 2011, 09:22 PM
