Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Results 1 to 3 of 3
Thread: Uninstall Revit from Command Line
    January 23, 2012
    26
    02:07 PM
    Wondering if anyone has luck uninstalling Revit from either a command line?
    I am trying to use this string to silent uninstall but it simply pops up the typical uninstall screen and waits for user interaction
    "C:\Program Files\Autodesk\Revit Architecture 2011\Program\Setup\Setup.exe" /P {94D463D0-2B13-4181-9512-B27004B1151A} /M REVIT /language en-US
    so then I tried adding the typical 'silent' switches that work with the install
    /W /q /l
    and then nothing seems to happen.
    Right now I am doing this with Revit Arch 2011 & 2012 without any luck... have not tried newer versions just yet.
    January 23, 2012
    26
    02:07 PM
    Thanks to Troy Gates... just use the standard MsiExec.exe with he GUID...
    MsiExec.exe /qn /norestart /X {94D463D0-2B13-4181-9512-B27004B1151A}
    Junior Member noss's Avatar
    July 11, 2011
    Brisbane, AU
    36
    05:07 AM
    Try this Building Design Suite Premium 2015 Unassisted Uninstaller | REVIT.AU it uses a power she'll script to uninstall whatever you want, in this case BDSP 2015 without any interaction required. You can find the required install guid of whatever software you want to uninstall by following the instructions
  1. Running Revit simulations via command line
    By arielw in forum Architecture - Family Creation
    Last Post: October 31st, 2014, 03:08 PM
  2. Replies: 0
    Last Post: October 8th, 2014, 01:15 PM
  3. Revit Server Uninstall??
    By Drew in forum Worksharing, Revit Server & C4R
    Last Post: July 13th, 2014, 08:14 AM
  4. Can't Uninstall Revit 2013 (Student)
    By nadieliz in forum Architecture and General Revit Questions
    Last Post: November 25th, 2012, 05:59 AM
  5. Revit Server Command Line Error
    By adeuley in forum Worksharing, Revit Server & C4R
    Last Post: July 13th, 2012, 02:25 AM
Tags for this Thread
