Page 1 of 15 1234511 ... LastLast
Results 1 to 10 of 147
Like Tree24Likes
Thread: RFOBenchmark 2015 results
    Berlin!
    2,390
    10:23 PM
    Please post your RFOBenchmark results for the 2015 products here.
    Comments and suggestions should be made in the RFOBenchmark thread. The download is there too.
    Thanks!
    Gordon
    Berlin!
    2,390
    10:23 PM
    RVT 2014 vs RVT 2015
    To kick things off I thought I would post the comparison run I did, to validate the changes in the test. Looks like 2015 really is just a bit quicker than 2014!
    And yes, I am jumping the gun a bit. The benchmark is being tested now. Should have downloads up so everyone can play very soon.
    Thanks!
    Gordon
    Code:
    RFO Benchmark RVT 2014 vs 2015
    All times are in seconds, lower is better.
    2014        2015
    Model creation and view export benchmark
    6.3          6.3        opening and loading the custom template
    25.8        22.8       creating the floors levels and grids
    49.2        45.1       creating a group of walls and doors
    79.2        82.3       modifying the group by adding a curtain wall
    35.1        27.1       creating the exterior curtain wall
    27.4        18.3       creating the sections
    15.8        12.8       changing the curtain wall panel type
    77.0        68.2       export all views as PNGs
    62.0        53.3       export some views as DWGs
    377.8      336.2     Total
    Render benchmark
    445.8    418.4    render
    GPU benchmark*
    25.1        22.9        refresh Hidden Line view x12 - with hardware acceleration
    20.2        18.0        refresh Consistent Colors view x12 - with hardware acceleration
    25.7        22.2        refresh Realistic view x12 - with hardware acceleration
    11.6        10.2        rotate view x1 - with hardware acceleration
    80.1        77.6        refresh Hidden Line view x12 - without hardware acceleration
    72.2        74.3        refresh Consistent Colors view x12 - without hardware acceleration
    77.7        76.7        refresh Realistic view x12 - without hardware acceleration
    49.4        48.2        rotate view x1 - without hardware acceleration
    * For Hardware Acceleration comparison only.
      Do not use the GPU benchmark
      for graphics card comparisons.
    MACHINE SPEC:
    OS: Microsoft Windows 7 Home Premium  64-bit
    CPU: Intel(R) Core(TM) i5-3330S CPU @ 2.70GHz
    Max Clock Speed: 2.70 GHz
    Number of Processors: 1
    Number of Logical Processors: 4
    Total Physical Memory: 4.00 GB
    BANK #0: 4.00 GB @ 667 MHz
    Graphics Card: Parallels Display Adapter (WDDM)
    Graphics RAM: 1.00 GB
    Driver version: 9.0.24229.0
    Screen Resolution: 1920X1080
    Benchmark was run full screen
    July 24, 2012
    1
    06:23 AM
    This is a VM with GPU Pass-through
    RFO Benchmark RVT 2015 build 05.07.2014 run at 9/05/2014 9:51:25 AMRevitForum.org
    9.8 opening and loading the custom template
    20.5 creating the floors levels and grids
    43.0 creating a group of walls and doors
    74.8 modifying the group by adding a curtain wall
    25.3 creating the exterior curtain wall
    19.2 creating the sections
    10.6 changing the curtain wall panel type
    45.0 export all views as PNGs
    50.3 export some views as DWGs
    298.5 Total
    Render benchmark
    214.9 render
    GPU benchmark*
    16.0 refresh Hidden Line view x12 - with hardware acceleration
    10.9 refresh Consistent Colors view x12 - with hardware acceleration
    15.0 refresh Realistic view x12 - with hardware acceleration
    7.0 rotate view x1 - with hardware acceleration
    53.7 refresh Hidden Line view x12 - without hardware acceleration
    48.6 refresh Consistent Colors view x12 - without hardware acceleration
    53.6 refresh Realistic view x12 - without hardware acceleration
    29.4 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    OS: Microsoft Windows 7 Professional 64-bit
    CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
    Max Clock Speed: 2.66 GHz
    Number of Logical Processors: 8
    Total Physical Memory: 12.00 GB
    : 12.00 GB @ MHz
    Graphics Card: Citrix Display Driver (Citrix Systems - WDDM)
    Graphics RAM:
    Driver version: 7.1.0.4049
    Graphics Card: Standard VGA Graphics Adapter
    Graphics RAM:
    Driver version: 6.1.7600.16385
    Graphics Card: Citrix Display Mirror Driver
    Graphics RAM:
    Driver version: 6.3.0.44
    Graphics Card: Citrix Systems Inc. Display Mirror Driver
    Graphics RAM:
    Driver version: 7.0.0.54
    Graphics Card: NVIDIA Quadro 2000
    Driver version: 9.18.13.3750
    Screen Resolution: 1626X978
    Screen Resolution: X
    January 10, 2012
    Las Vegas
    24
    01:23 PM
    RFO Benchmark RVT 2015 build 05.07.2014 run at 5/9/2014 8:38:50 AM
    RevitForum.org
    5.6 opening and loading the custom template
    7.3 creating the floors levels and grids
    20.2 creating a group of walls and doors
    38.4 modifying the group by adding a curtain wall
    12.3 creating the exterior curtain wall
    7.5 creating the sections
    5.5 changing the curtain wall panel type
    20.4 export all views as PNGs
    27.7 export some views as DWGs
    144.9 Total
    Render benchmark
    180.4 render
    GPU benchmark*
    9.9 refresh Hidden Line view x12 - with hardware acceleration
    6.2 refresh Consistent Colors view x12 - with hardware acceleration
    7.3 refresh Realistic view x12 - with hardware acceleration
    3.7 rotate view x1 - with hardware acceleration
    37.1 refresh Hidden Line view x12 - without hardware acceleration
    34.2 refresh Consistent Colors view x12 - without hardware acceleration
    35.8 refresh Realistic view x12 - without hardware acceleration
    24.4 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
    Max Clock Speed: 3.50 GHz
    Total Physical Memory: 15.95 GB
    BANK 0: 4.00 GB @ 1867 MHz
    BANK 1: 4.00 GB @ 1867 MHz
    BANK 2: 4.00 GB @ 1867 MHz
    BANK 3: 4.00 GB @ 1867 MHz
    Graphics Card: NVIDIA Quadro K5000
    Graphics RAM: -1 MB
    Driver version: 9.18.13.3182
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    697
    03:23 PM
    2015 vs 2014 with project files from platter drive
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 5/10/2014 9:24:20 PM
    RevitForum.org
    2015	2014
    5.3	5.4	 opening and loading the custom template
    10.6	12.1	 creating the floors levels and grids
    26.2	29.2	 creating a group of walls and doors
    43.0	46.8	 modifying the group by adding a curtain wall
    15.2	20.1	 creating the exterior curtain wall
    9.6	13.7	 creating the sections
    6.9	9.3	 changing the curtain wall panel typea
    29.2	28.8	 export all views as PNGs
    38.9	39.5	 export some views as DWGs
    184.9	204.9	 Total
    Render benchmark
    194.3	208.2	 render
    GPU benchmark*
    13.3	14.9	 refresh Hidden Line view x12 - with hardware acceleration
    8.0	8.3	 refresh Consistent Colors view x12 - with hardware acceleration
    9.3	11.0	 refresh Realistic view x12 - with hardware acceleration
    4.8	5.3	 rotate view x1 - with hardware acceleration
    48.2	49.0	 refresh Hidden Line view x12 - without hardware acceleration
    44.0	44.0	 refresh Consistent Colors view x12 - without hardware acceleration
    45.0	46.4	 refresh Realistic view x12 - without hardware acceleration
    29.7	31.4	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    OS: Microsoft Windows 8.1 Pro 64-bit
    CPU: AMD FX(tm)-9370 Eight-Core Processor
    Max Clock Speed: 4.42 GHz
    Total Physical Memory: 15.92 GB
    BANK1: 8.00 GB @ 1866 MHz
    BANK3: 8.00 GB @ 1866 MHz
    Graphics Card: NVIDIA GeForce GTX 780
    Graphics RAM: -1,024 MB
    Driver version: 9.18.13.3523
    Screen Resolution: 1680X1050
    2015 vs 2014 with project files from SSD
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 5/10/2014 10:13:27 PM
    RevitForum.org
    2015	2014
    5.1	5.0	 opening and loading the custom template
    10.8	12.2	 creating the floors levels and grids
    27.3	30.8	 creating a group of walls and doors
    44.1	49.1	 modifying the group by adding a curtain wall
    15.5	20.5	 creating the exterior curtain wall
    10.0	13.9	 creating the sections
    7.0	9.5	 changing the curtain wall panel type
    29.7	29.0	 export all views as PNGs
    35.2	38.3	 export some views as DWGs
    184.7	208.3	 Total
    Render benchmark
    197.7	211.1	 render
    GPU benchmark*
    13.5	15.2	 refresh Hidden Line view x12 - with hardware acceleration
    9.3	11.1	 refresh Realistic view x12 - with hardware acceleration
    4.9	5.3	 rotate view x1 - with hardware acceleration
    49.6	50.5	 refresh Hidden Line view x12 - without hardware acceleration
    45.1	45.5	 refresh Consistent Colors view x12 - without hardware acceleration
    46.7	47.6	 refresh Realistic view x12 - without hardware acceleration
    30.2	32.6	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    April 21, 2011
    Oklahoma
    697
    03:23 PM
    Some results from a new workstation build at the office:
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 5/21/2014 8:45:24 AM
    RevitForum.org
    13.4	 opening and loading the custom template
    14.6	 creating the floors levels and grids
    30.0	 creating a group of walls and doors
    54.1	 modifying the group by adding a curtain wall
    18.9	 creating the exterior curtain wall
    14.4	 creating the sections
    8.4	 changing the curtain wall panel type
    30.5	 export all views as PNGs
    56.4	 export some views as DWGs
    240.7	 Total
    Render benchmark
    237.1	 render
    GPU benchmark*
    13.6	 refresh Hidden Line view x12 - with hardware acceleration
    8.2	 refresh Consistent Colors view x12 - with hardware acceleration
    9.6	 refresh Realistic view x12 - with hardware acceleration
    5.1	 rotate view x1 - with hardware acceleration
    52.8	 refresh Hidden Line view x12 - without hardware acceleration
    46.6	 refresh Consistent Colors view x12 - without hardware acceleration
    49.8	 refresh Realistic view x12 - without hardware acceleration
    32.3	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz
    Max Clock Speed: 3.70 GHz
    Total Physical Memory: 31.95 GB
    Graphics Card: AMD FirePro W5000 (FireGL V) Graphics Adapter
    Graphics RAM: -2,048 MB
    Driver version: 13.251.1.0
    and an updated spreadsheet to include the 2015 tab: https://docs.google.com/spreadsheet/...3c&usp=sharing
    Last edited by rkitect; May 21st, 2014 at 03:08 PM. Reason: Added updated spreadsheet
    Austin, Texas
    240
    03:23 PM
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 5/21/2014 11:51:30 AM
    RevitForum.org
    3.8	 opening and loading the custom template
    7.4	 creating the floors levels and grids
    18.7	 creating a group of walls and doors
    33.9	 modifying the group by adding a curtain wall
    11.2	 creating the exterior curtain wall
    8.2	 creating the sections
    5.1	 changing the curtain wall panel type
    23.4	 export all views as PNGs
    25.2	 export some views as DWGs
    136.9	 Total
    Render benchmark
    183.6	 render
    GPU benchmark*
    9.1	 refresh Hidden Line view x12 - with hardware acceleration
    5.0	 refresh Consistent Colors view x12 - with hardware acceleration
    6.0	 refresh Realistic view x12 - with hardware acceleration
    3.3	 rotate view x1 - with hardware acceleration
    124.6	 refresh Hidden Line view x12 - without hardware acceleration
    119.6	 refresh Consistent Colors view x12 - without hardware acceleration
    121.0	 refresh Realistic view x12 - without hardware acceleration
    84.7	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
    Max Clock Speed: 3.40 GHz
    : 4.00 GB @ 1600 MHz
    Graphics Card: NVIDIA GeForce GTX 660
    Graphics RAM: 1.50 GB
    Driver version: 9.18.13.3489
    Screen Resolution: 1920X1200
    January 17, 2011
    1,007
    03:23 PM
    Here is mine from my work computer:
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 5/21/2014 11:18:40 AM
    RevitForum.org
    3.6	 opening and loading the custom template
    19.6	 creating a group of walls and doors
    33.3	 modifying the group by adding a curtain wall
    11.5	 creating the exterior curtain wall
    8.8	 creating the sections
    5.0	 changing the curtain wall panel type
    18.9	 export all views as PNGs
    21.4	 export some views as DWGs
    129.4	 Total
    Render benchmark
    191.3	 render
    GPU benchmark*
    9.0	 refresh Hidden Line view x12 - with hardware acceleration
    5.2	 refresh Consistent Colors view x12 - with hardware acceleration
    6.2	 refresh Realistic view x12 - with hardware acceleration
    3.5	 rotate view x1 - with hardware acceleration
    50.4	 refresh Hidden Line view x12 - without hardware acceleration
    50.2	 refresh Consistent Colors view x12 - without hardware acceleration
    53.2	 refresh Realistic view x12 - without hardware acceleration
    39.6	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-4910MQ CPU @ 2.90GHz
    Max Clock Speed: 2.90 GHz
    BANK 0: 8.00 GB @ 1600 MHz
    BANK 1: 8.00 GB @ 1600 MHz
    BANK 2: 8.00 GB @ 1600 MHz
    BANK 3: 8.00 GB @ 1600 MHz
    Graphics Card: NVIDIA GeForce GTX 880M
    Graphics RAM: -1 MB
    Driver version: 9.18.13.3260
    Graphics RAM: -1 MB
    Screen Resolution: 2560X1440
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    199
    10:23 PM
    Everything is around 5% better than in 2014:
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 22.5.2014. 10:21:04
    RevitForum.org
    3,0	003906
    7,0	078125
    17,0	6875
    32,0	60547
    10,0	68359
    7,0	597656
    4,0	730469
    18,0	88281
    21,0	32813
    119,0	 Total
    Render benchmark
    178,0	6641
    GPU benchmark*
    7,0	929688
    4,0	636719
    5,0	449219
    3,0	242188
    30,0	45313
    31,0	35156
    36,0	72266
    22,0	33984
    MACHINE SPEC:
    Max Clock Speed: 3,40 GHz
    Total Physical Memory: 15,93 GB
    BANK 0: 8,00 GB @ 1333 MHz
    BANK 2: 8,00 GB @ 1333 MHz
    Graphics Card: NVIDIA GeForce GTX 760
    Graphics RAM: - 2.048 MB
    May 23, 2014
    2
    08:23 PM
    Dell percision T1700
    Benchmark results on a Dell Percision T1700 Workstation with a 256 Gb SSD.
    Price of the machine is around 1400 euro.
    Code:
    RFO Benchmark RVT 2015 build 05.07.2014 run at 23-5-2014 9:57:58
    RevitForum.org
    3,0 027344
    6,0 683594
    17,0 92969
    33,0 96875
    10,0 80078
    7,0 035156
    4,0 8125
    20,0 25
    23,0 05469
    123,0  Total
    Render benchmark
    187,0 7539
    GPU benchmark*
    8,0 386719
    5,0 226563
    6,0 125
    3,0 21875
    35,0 40234
    33,0 03906
    33,0 79688
    20,0 20703
    MACHINE SPEC:
    OS: Microsoft Windows 7 Enterprise  64-bit
    Total Physical Memory: 31,93 GB
    : 8,00 GB @ 1600 MHz
    Graphics Card: NVIDIA Quadro K2000
    Graphics RAM: -2.048 MB
    Driver version: 9.18.13.1115
    Screen Resolution: 1280X1024
  1. RFOBenchmark 2014 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: March 2nd, 2015, 09:56 PM
  2. RFOBenchmark 2013 results
    Last Post: August 14th, 2014, 04:22 PM
  3. RFOBenchmark for Revit 2015
    By jonz in forum Architecture and General Revit Questions
    Last Post: May 28th, 2014, 02:17 PM
  4. RFOBenchmark 2012 results
    Last Post: April 11th, 2013, 04:22 PM
  5. RFOBenchmark 2011 results
    Last Post: December 26th, 2012, 08:40 PM
