Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 79
Like Tree3Likes
Thread: RFOBenchmark 2014 results
    Berlin!
    2,104
    01:39 AM
    Please post your RFOBenchmark results for the 2014 products here.
    Comments and suggestions should be made in the RFOBenchmark thread. The download is there too.
    Thanks!
    Gordon
    Austin, Texas
    238
    06:39 PM
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 7/30/2013 8:23:33 AM
    RevitForum.org
    Model creation and view export benchmark
    8.4	 opening and loading the custom template
    10.6	 creating the floors levels and grids
    25.5	 creating a group of walls and doors
    43.9	 modifying the group by adding a curtain wall
    16.5	 creating the exterior curtain wall
    13.0	 creating the sections
    7.7	 changing the curtain wall panel type
    21.7	 export all views as PNGs
    38.5	 export some views as DWGs
    185.8	 Total
    Render benchmark
    236.9	 render
    GPU benchmark*
    13.3	 refresh Hidden Line view x12 - with hardware acceleration
    8.2	 refresh Consistent Colors view x12 - with hardware acceleration
    10.9	 refresh Realistic view x12 - with hardware acceleration
    4.9	 rotate view x1 - with hardware acceleration
    54.0	 refresh Hidden Line view x12 - without hardware acceleration
    52.7	 refresh Consistent Colors view x12 - without hardware acceleration
    56.1	 refresh Realistic view x12 - without hardware acceleration
    37.7	 rotate view x1 - without hardware acceleration
    * For Hardware Acceleration comparison only.
      Do not use the GPU benchmark
      for graphics card comparisons.
    MACHINE SPEC:
    OS: Microsoft Windows 7 Professional  64-bit
    CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
    Max Clock Speed: 3.40 GHz
    Number of Processors: 1
    Number of Logical Processors: 8
    Total Physical Memory: 15.96 GB
    BANK 0: 4.00 GB @ 1600 MHz
    BANK 1: 4.00 GB @ 1600 MHz
    BANK 2: 4.00 GB @ 1600 MHz
    BANK 3: 4.00 GB @ 1600 MHz
    Graphics Card: NVIDIA GeForce GTX 660
    Graphics RAM: 1.50 GB
    Driver version: 9.18.13.2049
    Screen Resolution: 1920X1200
    Benchmark was run full screen
    Austin, Texas
    238
    06:39 PM
    This is a coworker's machine which is almost identical to mine:
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 7/30/2013 8:43:56 AM
    RevitForum.org
    7.9	 opening and loading the custom template
    9.6	 creating the floors levels and grids
    24.8	 creating a group of walls and doors
    42.9	 modifying the group by adding a curtain wall
    15.8	 creating the exterior curtain wall
    11.2	 creating the sections
    7.6	 changing the curtain wall panel type
    21.3	 export all views as PNGs
    35.4	 export some views as DWGs
    176.5	 Total
    Render benchmark
    218.8	 render
    GPU benchmark*
    13.0	 refresh Hidden Line view x12 - with hardware acceleration
    7.8	 refresh Consistent Colors view x12 - with hardware acceleration
    11.1	 refresh Realistic view x12 - with hardware acceleration
    4.4	 rotate view x1 - with hardware acceleration
    53.4	 refresh Hidden Line view x12 - without hardware acceleration
    49.0	 refresh Consistent Colors view x12 - without hardware acceleration
    51.9	 refresh Realistic view x12 - without hardware acceleration
    33.9	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    Graphics RAM: 2.00 GB
    Driver version: 9.18.13.1422
    Member need4mospd's Avatar
    March 2, 2011
    Houston
    433
    06:39 PM
    I ran the test three times, this result seems to be the most accurate as it hung up in a couple spots on the other tests.
    Code:
    RFO Benchmark RAC 2014 build 07.26.2013 run at 7/31/2013 10:19:59 AM
    RevitForum.org
    5.3	 opening and loading the custom template
    12.0	 creating the floors levels and grids
    27.8	 creating a group of walls and doors
    44.9	 modifying the group by adding a curtain wall
    18.7	 creating the exterior curtain wall
    14.8	 creating the sections
    8.7	 changing the curtain wall panel type
    27.1	 export all views as PNGs
    48.2	 export some views as DWGs
    207.5	 Total
    Render benchmark
    234.6	 render
    GPU benchmark*
    20.3	 refresh Hidden Line view x12 - with hardware acceleration
    12.2	 refresh Consistent Colors view x12 - with hardware acceleration
    15.2	 refresh Realistic view x12 - with hardware acceleration
    8.3	 rotate view x1 - with hardware acceleration
    44.4	 refresh Hidden Line view x12 - without hardware acceleration
    40.7	 refresh Consistent Colors view x12 - without hardware acceleration
    43.9	 refresh Realistic view x12 - without hardware acceleration
    28.0	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
    Total Physical Memory: 7.70 GB
    BANK 0: 4.00 GB @ 1333 MHz
    BANK 2: 4.00 GB @ 1333 MHz
    Graphics Card: Intel(R) HD Graphics 3000
    Graphics RAM: -1,796 MB
    Driver version: 9.17.10.2932
    Screen Resolution: 1280X1024
    Benchmark was NOT run full screen
    It was run at full screen, but it's on an old 17" monitor.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    4,962
    06:39 PM
    Work machine with a Xeon processor.
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 7/31/2013 2:02:04 PM
    RevitForum.org
    4.6	 opening and loading the custom template
    9.5	 creating the floors levels and grids
    25.3	 creating a group of walls and doors
    45.0	 modifying the group by adding a curtain wall
    17.6	 creating the exterior curtain wall
    12.0	 creating the sections
    25.3	 export all views as PNGs
    35.2	 export some views as DWGs
    182.2	 Total
    Render benchmark
    225.0	 render
    GPU benchmark*
    13.7	 refresh Hidden Line view x12 - with hardware acceleration
    8.3	 refresh Consistent Colors view x12 - with hardware acceleration
    10.5	 refresh Realistic view x12 - with hardware acceleration
    4.2	 rotate view x1 - with hardware acceleration
    49.5	 refresh Consistent Colors view x12 - without hardware acceleration
    52.4	 refresh Realistic view x12 - without hardware acceleration
    26.6	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
    Max Clock Speed: 3.60 GHz
    Graphics Card: NVIDIA Quadro FX 4800
    Driver version: 9.18.13.1135
    Graphics Card: NVIDIA Quadro 2000
    Graphics RAM: 1.00 GB
    I'll run my home machine with a 3770K and an SSD drive tonight.
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    567
    07:39 PM
    Code:
    RFO Benchmark RAC 2014 build 07.26.2013 run at 7/31/2013 5:00:18 PM
    RevitForum.org
    12.1	 opening and loading the custom template
    9.3	 creating the floors levels and grids
    24.3	 creating a group of walls and doors
    43.2	 modifying the group by adding a curtain wall
    16.4	 creating the exterior curtain wall
    12.4	 creating the sections
    21.9	 export all views as PNGs
    38.0	 export some views as DWGs
    185.2	 Total
    Render benchmark
    222.9	 render
    GPU benchmark*
    13.5	 refresh Hidden Line view x12 - with hardware acceleration
    7.9	 refresh Consistent Colors view x12 - with hardware acceleration
    10.3	 refresh Realistic view x12 - with hardware acceleration
    4.8	 rotate view x1 - with hardware acceleration
    48.3	 refresh Hidden Line view x12 - without hardware acceleration
    44.8	 refresh Consistent Colors view x12 - without hardware acceleration
    48.3	 refresh Realistic view x12 - without hardware acceleration
    32.3	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
    Max Clock Speed: 3.50 GHz
    Total Physical Memory: 15.95 GB
    BANK 0: 8.00 GB @ 1333 MHz
    BANK 2: 8.00 GB @ 1333 MHz
    Driver version: 9.18.13.1106
    Screen Resolution: 1920X1080
    dzatto's Avatar
    December 9, 2010
    4,962
    06:39 PM
    This is my home machine. The rendering was a tad bit better, but the model creation was a tad bit slower. My work video card killed my home one.
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 8/1/2013 9:39:30 PM
    RevitForum.org
    3.8	 opening and loading the custom template
    8.7	 creating the floors levels and grids
    25.8	 creating a group of walls and doors
    43.5	 modifying the group by adding a curtain wall
    17.0	 creating the exterior curtain wall
    12.1	 creating the sections
    43.9	 export all views as PNGs
    33.6	 export some views as DWGs
    196.1	 Total
    Render benchmark
    220.6	 render
    GPU benchmark*
    13.2	 refresh Hidden Line view x12 - with hardware acceleration
    7.7	 refresh Consistent Colors view x12 - with hardware acceleration
    10.7	 refresh Realistic view x12 - with hardware acceleration
    25.8	 rotate view x1 - with hardware acceleration
    60.0	 refresh Hidden Line view x12 - without hardware acceleration
    61.1	 refresh Consistent Colors view x12 - without hardware acceleration
    59.4	 refresh Realistic view x12 - without hardware acceleration
    57.5	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
    Graphics Card: NVIDIA GeForce GTX 660 Ti
    Graphics RAM: -2,048 MB
    Mod Edit: You can follow the discussion about this post here RFOBenchmark #363 and here RFOBenchmark #364
    Last edited by Alex Cunningham; August 2nd, 2013 at 02:56 PM. Reason: added redirect
    Member Cyus's Avatar
    July 10, 2012
    London / MK
    436
    12:39 AM
    Work Machine:
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 02/08/2013 08:00:45
    RevitForum.org
    21.3     opening and loading the custom template
    21.2     creating the floors levels and grids
    38.8     creating a group of walls and doors
    62.7     modifying the group by adding a curtain wall
    25.7     creating the exterior curtain wall
    19.7     creating the sections
    11.3     changing the curtain wall panel type
    33.6     export all views as PNGs
    51.9     export some views as DWGs
    286.2     Total
    Render benchmark
    394.1     render
    GPU benchmark*
    19.2     refresh Hidden Line view x12 - with hardware acceleration
    11.8     refresh Consistent Colors view x12 - with hardware acceleration
    15.7     refresh Realistic view x12 - with hardware acceleration
    6.6     rotate view x1 - with hardware acceleration
    79.2     refresh Hidden Line view x12 - without hardware acceleration
    71.9     refresh Consistent Colors view x12 - without hardware acceleration
    74.9     refresh Realistic view x12 - without hardware acceleration
    40.1     rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Xeon(R) CPU           W3530  @ 2.80GHz
    Max Clock Speed: 2.80 GHz
    Number of Logical Processors: 4
    Total Physical Memory: 12.00 GB
    : 2.00 GB @ 1333 MHz
    Graphics Card: NVIDIA Quadro FX 1800
    Graphics RAM: 768 MB
    Driver version: 9.18.13.2000
    Screen Resolution: 2560X1600
    Will post a home one later on.
    Austin, Texas
    238
    06:39 PM
    Our newest work machine with an i7 4770
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 8/1/2013 1:41:40 PM
    RevitForum.org
    12.9	 opening and loading the custom template
    9.7	 creating the floors levels and grids
    20.1	 creating a group of walls and doors
    31.9	 modifying the group by adding a curtain wall
    12.4	 creating the exterior curtain wall
    5.4	 changing the curtain wall panel type
    17.4	 export all views as PNGs
    32.7	 export some views as DWGs
    152.2	 Total
    Render benchmark
    193.0	 render
    GPU benchmark*
    5.1	 refresh Consistent Colors view x12 - with hardware acceleration
    6.8	 refresh Realistic view x12 - with hardware acceleration
    3.2	 rotate view x1 - with hardware acceleration
    48.0	 refresh Hidden Line view x12 - without hardware acceleration
    43.7	 refresh Consistent Colors view x12 - without hardware acceleration
    46.7	 refresh Realistic view x12 - without hardware acceleration
    32.2	 rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
    Total Physical Memory: 15.94 GB
    Graphics Card: NVIDIA GeForce GTX 650 Ti
    July 27, 2013
    1
    05:39 PM
    Many Thanks, Gordon, for the benchmark - it's been very useful.
    Haswell build for a Structural Engineer:
    Intel i5-4670K overclocked to 4.5ghz**
    Corsair Vengeance Pro ram rated at 2400mhz (1.65v)
    Samsung 840 pro 256gb ssd
    screen resolution: 1920x1200 (Revit Structure UI)
    comparison visualization of following data in file attached
    overclocked, NVIDIA Quadro K2000
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 8/2/2013 8:52:24 PM
    RevitForum.org
    3.0     opening and loading the custom template
    6.5     creating the floors levels and grids
    17.2     creating a group of walls and doors
    30.1     modifying the group by adding a curtain wall
    12.0     creating the exterior curtain wall
    8.3     creating the sections
    5.3     changing the curtain wall panel type
    15.5     export all views as PNGs
    21.3     export some views as DWGs
    119.2     Total
    Render benchmark
    195.8     render
    GPU benchmark*
    7.8     refresh Hidden Line view x12 - with hardware acceleration
    4.4     refresh Consistent Colors view x12 - with hardware acceleration
    5.6     refresh Realistic view x12 - with hardware acceleration
    2.8     rotate view x1 - with hardware acceleration
    33.3     refresh Hidden Line view x12 - without hardware acceleration
    30.2     refresh Consistent Colors view x12 - without hardware acceleration
    32.8     refresh Realistic view x12 - without hardware acceleration
    22.6     rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    OS: Microsoft Windows 8 Pro 64-bit
    CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
    BANK 1: 8.00 GB @ 2400 MHz
    BANK 3: 8.00 GB @ 2400 MHz
    Graphics Card: NVIDIA Quadro K2000
    Driver version: 9.18.13.745
    Screen Resolution: X
    not overclocked, NVIDIA Quadro K2000
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 8/2/2013 8:03:27 PM
    RevitForum.org
    3.4     opening and loading the custom template
    8.0     creating the floors levels and grids
    20.9     creating a group of walls and doors
    34.6     modifying the group by adding a curtain wall
    14.1     creating the exterior curtain wall
    10.7     creating the sections
    6.3     changing the curtain wall panel type
    18.6     export all views as PNGs
    25.4     export some views as DWGs
    142.0     Total
    Render benchmark
    249.9     render
    GPU benchmark*
    9.1     refresh Hidden Line view x12 - with hardware acceleration
    5.2     refresh Consistent Colors view x12 - with hardware acceleration
    6.7     refresh Realistic view x12 - with hardware acceleration
    3.4     rotate view x1 - with hardware acceleration
    42.0     refresh Hidden Line view x12 - without hardware acceleration
    39.7     refresh Consistent Colors view x12 - without hardware acceleration
    41.3     refresh Realistic view x12 - without hardware acceleration
    30.0     rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    BANK 1: 8.00 GB @ 1333 MHz
    BANK 3: 8.00 GB @ 1333 MHz
    overclocked, HD Graphics 4600
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 8/2/2013 8:36:05 PM
    RevitForum.org
    3.1     opening and loading the custom template
    8.8     creating the floors levels and grids
    18.3     creating a group of walls and doors
    30.0     modifying the group by adding a curtain wall
    12.6     creating the exterior curtain wall
    10.6     creating the sections
    5.8     changing the curtain wall panel type
    16.7     export all views as PNGs
    21.4     export some views as DWGs
    127.3     Total
    Render benchmark
    192.3     render
    GPU benchmark*
    8.3     refresh Hidden Line view x12 - with hardware acceleration
    4.8     refresh Consistent Colors view x12 - with hardware acceleration
    6.2     refresh Realistic view x12 - with hardware acceleration
    31.6     refresh Hidden Line view x12 - without hardware acceleration
    28.7     refresh Consistent Colors view x12 - without hardware acceleration
    31.1     refresh Realistic view x12 - without hardware acceleration
    21.7     rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    Total Physical Memory: 15.69 GB
    Graphics Card: Intel(R) HD Graphics 4600
    Graphics RAM: -1,792 MB
    Driver version: 9.18.10.3165
    not overclocked, HD Graphics 4600
    Code:
    RFO Benchmark RVT 2014 build 07.26.2013 run at 8/2/2013 8:18:14 PM
    RevitForum.org
    3.6     opening and loading the custom template
    10.3     creating the floors levels and grids
    22.2     creating a group of walls and doors
    35.0     modifying the group by adding a curtain wall
    14.9     creating the exterior curtain wall
    12.5     creating the sections
    6.7     changing the curtain wall panel type
    20.2     export all views as PNGs
    25.5     export some views as DWGs
    150.9     Total
    Render benchmark
    238.3     render
    GPU benchmark*
    9.5     refresh Hidden Line view x12 - with hardware acceleration
    5.5     refresh Consistent Colors view x12 - with hardware acceleration
    7.2     refresh Realistic view x12 - with hardware acceleration
    41.1     refresh Hidden Line view x12 - without hardware acceleration
    38.3     refresh Consistent Colors view x12 - without hardware acceleration
    40.1     refresh Realistic view x12 - without hardware acceleration
    27.7     rotate view x1 - without hardware acceleration
    MACHINE SPEC:
    **auto-overclocked using ASUS TurboV evo, then manually increased the core ratios to 45 45 44 44 (adaptive voltage offset of 0.175v) I decided set the 'minimum processor state' to 95% under windows power options to allow the processor to vdroop to the normal 3.4ghz when at idle. (Corsair H90 liquid cpu cooler in use, 75░C max under 100% cpu load - Revit visual style: Ray Trace)
    Attached Thumbnails Attached Thumbnails RFOBenchmark 2014 results-visualization.png
  1. RFOBenchmark
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: July 14th, 2014, 07:03 PM
  2. RFOBenchmark 2013 results
    Last Post: May 25th, 2014, 08:27 PM
  3. RFOBenchmark 2012 results
    Last Post: April 11th, 2013, 04:22 PM
  4. Different Analysis results for the same model
    By aA13 in forum Structure - Family Creation
    Last Post: January 29th, 2013, 02:36 AM
  5. RFOBenchmark 2011 results
    Last Post: December 26th, 2012, 08:40 PM
