Donate Now Goal amount for this year: 3000 USD, Received: 1130 USD (38%)
Results 1 to 9 of 9
Thread: Creating Basement Floors
    January 18, 2011
    63
    04:05 AM
    Basement Section.pdfHi
    I always have a confusion of creating basement floors. Can you guys suggest me the best way of doing it. Particularly if i taken a section through it, i want it like as it is in the attachment with all soil fills and what if the extend of basement differs. .
    Thanks
    Kingdom of Denmark
    3,975
    12:35 AM
    To get it to look like that, I´d just create a very thin floor. And if the extend (depth?) of the basement differs, I´d use multiple (very thin) floors at different levels.
    Miami, FL, USA | info@planta1.com
    1,633
    06:35 PM
    Quote Originally Posted by theshell07 View Post
    Thanks
    You need to create some building pads in plan view, with different offsets from the ground floor, to make the terrain adjust correctly to the basement floors in section views.
    See attached.
    Attached Thumbnails Attached Thumbnails Creating Basement Floors-building-pads.jpg
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    4,059
    05:35 PM
    I've never really gotten into building pads. They automatically cut into the terrain? Nice, I'll have to remember that.
    Member Ben-May's Avatar
    December 8, 2010
    Melbourne,Oz
    295
    08:35 AM
    Quote Originally Posted by dzatto View Post
    Be prepared for some of this... Building Pads are painful...
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,120
    08:35 AM
    Quote Originally Posted by Ben-May View Post
    Totally Agree with Ben on this one, pads are simply awful!
    I find a much better methodology is to duplicate the topography - hide the existing in the new construction phase and then use the split surface - merge tools to cut the site to the required depth and from there use the normal floor tools. If I mess it up completely or if the design changes substantially, I simply delete the entire new topo and recreate from the beginning. There are a whole lot of words I could use to describe Pads, but all of them are on our censor list.
    JTB
    JTB is offline
    Member JTB's Avatar
    December 30, 2010
    Athens, Greece
    121
    01:35 AM
    I agree, pads are not as they should be, but for this case I think they work ok and it is the fastest solution.
    Junior Member Stuntmonkee's Avatar
    December 8, 2010
    Phoenix, Arizona, USA
    37
    03:35 PM
    See attached.
    Building pads are the way to go on this. The difficult part that I'm seeing on your section is that you have soil filling back over your basement slab.
    I would probably create the pads exactly how Alfredo showed you, and then model in the floorslabs in the topography as needed. Might have a few visibility issues with the earth pattern merging with the conc. pattern, but you won't see it at the scale you are showing there, so no worries.
    I have pretty good luck with slabs. You just have to know when and where to expect issues. For something as simple as the section youre showing, you shouldnt have any issues.
    The only real rule is that you can't overlap a slab. The tricky part is figuing out what that means to Revit. . .hehe.
    One last tip. I will often create a 3D site plan with all of my pads and topography in a seperate file, and then link that it. Not something you have to do, but it helps with my workflow when I have a complicated site.
    March 21, 2011
    Norway
    1
    11:35 PM
    I made a buiding pad the way Alfredo explained (I also have some ramps between the differennt levels, since this i a parking)
    But i get a very very thin wall around every building pad.
    when the level between the pads is different it ok,
    but when it makes around the ramps I want to delete it.
    is there any way to delete them??
    seems like you guys don't like building pads
  1. Failure Creating Deployment
    By cblackford in forum Architecture and General Revit Questions
    Last Post: May 13th, 2011, 04:07 PM
  2. How to dimension typical (or very similar) floors in a tower?
    By Alfredo Medina in forum Architecture and General Revit Questions
    Last Post: April 19th, 2011, 10:29 PM
  3. Creating Views
    By cwwalder in forum MEP - General
    Last Post: February 9th, 2011, 05:51 PM
  4. Creating views
    Last Post: January 18th, 2011, 03:24 PM
  5. Creating Section causes Regens
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: December 30th, 2010, 07:34 PM
