Results 1 to 4 of 4
Thread: 3D View - Section Box Not Working
    Senior Member domsib's Avatar
    April 30, 2012
    516
    06:52 PM
    I have created a 3D view and this gives me the entire building. I only need to show a small part of this building for my 3D view.
    I click the building and the big purple box appears around the model. However I cannot select the edges of this box and drag them in to where I need them.
    In the properties pallette for the 3D view the section box is checked so I am unsure what else to do.
    I can also add that the model I am working on is a linked revit file into my current project.
    Any advice?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    06:52 PM
    The big purple thingie you're seeing when selecting the building isn't the section box. That's the outer edge of the link. Below your drawing window there's a bar with some icons. Try the lightbulb and see if the section box pops up.
    btw: hoovering over an element with your mouse results in a text bottom right of your screen indicating what it is. Could be helpful!
    Moderator LeanneZ's Avatar
    December 8, 2010
    Charlotte, NC
    692
    01:52 PM
    Adding to Martijn's post, check your Visibility Graphics > Annotation Categories > make sure Section Boxes is checked.
    If it is, maybe your 3d view is locked? Along that same lower icon bar with the lightbulb is what looks like a house with a padlock. Check to make sure the view is not locked.
    April 30, 2012
    516
    06:52 PM
    I had the reveal hidden elements light bulb switched off. Soon as I switched it on I was able to move the section box about.
    Thank You
  1. height parameter only working for plan but not for elevation view
    By kunster in forum Architecture - Family Creation
    Last Post: August 8th, 2012, 04:41 PM
  2. How to view Section view lines on a plan view bigger than 1:100 scale
    By eks_al in forum Architecture and General Revit Questions
    Last Post: January 18th, 2012, 12:41 AM
  3. Section view
    By DeNNoW87 in forum Structure - General Questions
    Last Post: November 8th, 2011, 01:04 PM
  4. Toposurface in section view
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 02:04 PM
  5. 3D View as Section?
    By WVReviter in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 06:09 PM
