Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Results 1 to 2 of 2
Thread: Keynotes & Note Blocks
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,021
    08:11 PM
    I'm looking at some of our bigger remodel projects and need some advice on notes. We have a standard set of notes for this client and they are for the most part the same in every job. In CAD there are demo keynotes, new work keynotes and a slew of general notes that aren't referenced directly. The general notes I can drop into a key schedule with no problem but I'm not sure what to do with the Demo and New notes. Combined there are close to 500 notes. Since I don't think I can use 2 keynote files I'm stuck with either a massive list of keynotes or... ? I know in the past I've seen it mentioned to use note blocks for demo notes but from what I can tell that would mean manually entering a ton of notes since it doesn't look like I can reference a schedule key to the generic annotations or import the notes in any way.
    Is there a better method for handling this?
    edit - Each set of notes is on it's own page, the plans barely fit on a 36x48 sheet, so note by sheet wouldn't really work either.
    August 9, 2011
    Louisville, KY
    5,021
    08:11 PM
    To add to this - is there a way to format keynotes with section headers? I would try to add a parameter but they are all greyed out in the schedule
    Section 1
    1.0 Note
    1.1 Note
    1.2 Note
    2.0 Note
    and so forth?
    My boss is climbing up my back about that and it isn't a battle I can win with rhetoric about how it looks vs data (also a client requirement)...
  1. How to properly note drawings? Tags, Keynotes, Text?
    By Mike Ferrell in forum Architecture and General Revit Questions
    Last Post: December 17th, 2014, 07:29 PM
  2. Revit export blocks to cad,..help
    Last Post: August 7th, 2012, 09:32 AM
  3. Replies: 0
    Last Post: August 3rd, 2012, 12:15 AM
  4. What Revit Wants: Using Note Blocks for Numbered Notes
    By luke.johnson in forum Blog Feeds
    Last Post: June 25th, 2012, 05:45 AM
  5. Multiple Keynotes in a .rfa AND/OR Scheduling Shared/Nested Keynotes
    Last Post: April 20th, 2011, 01:02 AM
