Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: text background
    Nantes, France
    1,380
    03:35 PM
    Question text background
    need your ideas and tips to make a text note have really a white background, and not only where the text is (see picture).
    thanks.
    Member Chadwick17's Avatar
    Fort Collins, CO
    309
    06:35 AM
    Masking region behind the text?
    Nantes, France
    1,380
    03:35 PM
    Quote Originally Posted by Chadwick17 View Post
    Yep, but not on sheets.... Only title blocks will achieve this I guess.
    thanks for your answer.
    Fort Collins, CO
    309
    06:35 AM
    You could create a drafting view that has the text and masking region behind. Then drag that view to where you want it on the sheet (make sure it has no view title). Kind of a clumsy workaround...
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,143
    11:35 PM
    I would set the text background to opaque rather than transparent in the text properties. This should give the result you are after.
    Nantes, France
    1,380
    03:35 PM
    Humm, If you look at the picture, the text has white background, but not until the border.It is set to opaque in fact. Only the letters are concerned, I would prefer the entire area within borders.
    1,143
    11:35 PM
    Sorry, misunderstood what you are after, (message to self - don't read so quickly!) and yep as others have noted it is going to be a bit of a kludge work around.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,187
    07:35 AM
    Quote Originally Posted by jbenoit44 View Post
    You can do a masking region on a sheet. Not sure how it will work on text though.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    01:35 PM
    Use a Generic Annotation.
    You can place a hardcoded text if it's something you will need to re-use every time.
    You can also create a instance text parameter if you want to be able to retyp the text as needed.
    use a filled region with invisible lines and white filling as a background and you're good to go. Do NOT use a masking region, this won't work.
    Attached Files Attached Files
    Member Ben-May's Avatar
    December 8, 2010
    Melbourne,Oz
    305
    12:35 AM
    Quote Originally Posted by mdradvies View Post
    You can't place a Generic anno in a 3D view though, looks like the image in the OP is a 3D view
  1. Symbols in Revit text
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: September 25th, 2015, 06:38 PM
  2. Revit and Text
    By Alex Cunningham in forum Tutorials, Tips & Tricks
    Last Post: June 3rd, 2015, 07:10 AM
  3. text in schedules
    By redmonki in forum Architecture and General Revit Questions
    Last Post: May 26th, 2011, 07:15 AM
  4. Text Leaders
    By Patrick in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 09:13 PM
  5. Dimension Text Leader
    By mark b in forum Architecture and General Revit Questions
    Last Post: January 20th, 2011, 04:20 AM
