Donate Now Goal amount for this year: 3000 USD, Received: 1448 USD (48%)
Results 1 to 1 of 1
Thread: Elevation Depth & Scope Boxes
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    4,849
    03:09 AM
    I'm trying to get an elevation tag to show up within an enlarged plan defined through a scope box but the actual view plane is quite a bit past the box which causes the tag to not show up in plan. Is there a trick to get this to work aside from using a new tag that references the actual elevation?
    Attached Thumbnails Attached Thumbnails Elevation Depth & Scope Boxes-elevation-cropping.jpg
  1. Managing Scope Boxes
    By Dandharma in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2015, 04:50 PM
  2. Notes with Boxes
    By MartinGT in forum Architecture and General Revit Questions
    Last Post: June 1st, 2012, 01:57 PM
  3. Section Boxes with options
    By goldring in forum Architecture and General Revit Questions
    Last Post: March 16th, 2012, 10:09 AM
  4. Revit OpEd: Scope Boxes
    Last Post: February 1st, 2012, 03:15 PM
  5. Revit Kid: Revit Tip - Using Scope Boxes
    By The Revit Kid in forum Blog Feeds
    Last Post: January 30th, 2012, 08:15 PM
