Donate Now Goal amount for this year: 3000 USD, Received: 1130 USD (38%)
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Steven Thedens
Thread: Use Omni Classification with Revit
    August 4, 2011
    2
    07:51 PM
    Question Use Omni Classification with Revit
    Hi there,
    Has anyone successfully deployed the use of Omni classification with Revit.
    Care to share what are the things to look out for? And also the benefits of such practice.
    Member kirklyncox's Avatar
    February 7, 2011
    66
    04:51 AM
    The 2.0 version of the National BIM Standard utilizes Omniclass information, check it out:
    http://www.wbdg.org/resources/omniclass.php
    http://www.nationalbimstandard.org/
    Junior Member Steven Thedens's Avatar
    May 2, 2012
    Omaha, Ne
    34
    06:51 AM
    The omniclass code for a toilet partition should be 23.15.11.15.11
    However, this is not a valid omniclass number in Revit. In fact you can't enter any of the 23.15 codes.
    snowyweston likes this.
    December 21, 2010
    C.LONDON
    1,539
    12:51 PM
    Quote Originally Posted by Steven Thedens View Post
    Joined up thinking again!
    Mr. Revit OpEd
    630
    04:51 AM
    The source file is separate, which means editable. Obviously it is incomplete as is. Revit system families are also immune to Omniclass data as they have no built in parameters for it and no way to reference the same data set if you make your own. Bit of a disconnect there eh?
    May 2, 2012
    Omaha, Ne
    34
    06:51 AM
    An example of when BIM becomes BM.
  1. Omni Class and Master Spec
    By jmussett in forum Architecture and General Revit Questions
    Last Post: May 31st, 2012, 05:53 PM
