Originally Posted by
stl4310
Ok, so I think I got it to work by mark b's method, thanks.
I'm still running into a problem with my curtain wall panel. What I have done to get my custom cutout pattern is create an extrusion for the panel, then traced my cutout pattern as a void extrusion and it cut the hosted extrusion properly. Then I loaded that into my curtain wall panel, but I can't get it to cut the panel properly, it just sits on top of the panel as a yellow outline. Is this one step to far, should I trace my void extrusion outline directly in the curtain wall panel family and not a separate face-based family?
Also, will this allow me to create panels of different heights and widths using the same void extrusion? It's a complicated pattern and I don't want to have to retrace it for every panel.
