I have two basic questions regarding Ref. planes:
1 - Ref. planes are always perpendicular to a chosen Elevation, but in the case of the picture I ended up needing a Plane that wasn't perpendicular to any of my existing Elevations. So I did the following:
- I created an extra wall perpendicular to my future Ref. plane
- Then I created an extra Elevation with this Wall.
- Finally I created the Ref. Plane that I wanted, sketching a line in the extra Elevation
Does anyone have an alternate way of doing this? As you can notice, this is just a workaround, and may not be the best way, even though I don't see any other way of doing it.
2 - In the picture you can see some Walls and my new Ref. plane. I want to cut those walls exactly where my Ref. plane is passing and make a roof. Can anyone help me with this one?
Thanks!!!
LinkBack URL
About LinkBacks
