Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree2Likes
Thread: Video Card
    United States
    1,111
    02:33 PM
    Video Card
    My company is looking at purchasing some new workstations. Here are the graphics cards he has listed...any thoughts? From my first glance none of the NVS seem to be Certified so that drops most. All 3 of the higher End Quadro cards had poor reviews on NewEgg
    Professional 2D graphic cards
    512MB NVIDIA® Quadro® NVS 420, Quad Monitor, 4DVI [add $310.00]
    512MB NVIDIA® Quadro® NVS 420, Quad Monitor, 4DP [add $310.00]
    Dual 512MB NVIDIA® Quadro® NVS 420, 8 Monitor, 8DVI [add $810.00]
    Dual 512MB NVIDIA® Quadro® NVS 420, 8 Monitor, 8DP [add $810.00]
    Dual 256MB NVIDIA® Quadro® NVS 295, 4MON, 4DP w/ 4DP to DVI Adapt [add $70.00]
    Dual 256MB ATI FireMV® 2260, 4MON, 4 DP w/ 4 DP to DVI Adapter [add $50.00]
    Entry 3D graphic cards
    1GB ATI FirePro V4800, Triple MON, 2 DP & 1 DVI [Included in Price]
    1GB ATI FirePro V4800, Six MON, 2 DP & 1 DVI [add $190.00]
    1.0GB NVIDIA® Quadro® 600, Dual MON, 1 DP & 1 DVI add $0.00
    Mid Range 3D graphic cards
    2.0GB AMD FirePro™ V7900, Triple Monitor, 4 DP [add $680.00]
    2GB NVIDIA® Quadro® 4000, DUAL MON, 2DP & 1DVI [add $770.00]
    1.0GB NVIDIA® Quadro® 2000, Dual MON, 2 DP & 1 DVI [add $385.00]
    2.0GB AMD FirePro™ V5900, Triple Monitor, 2DP & 1DVI [add $290.00]
    Dual 1.0GB NVIDIA® Quadro® 2000, Quad MON, 4 DP & 2 DVI [add $950.00]
    High End 3D graphic cards
    2.5GB NVIDIA® Quadro® 5000, DUAL MON, 2DP & 1DVI [add $1,870.00]
    Kingdom of Denmark
    4,046
    10:33 PM
    Pure Revit workstations? Or will other software be used?
    If purely Revit, the Quadro cards are overkill IMO... Ask for a GTX (Gamer) card instead.
    United States
    1,111
    02:33 PM
    Revit, some (little) Navisworks Sim, SDS/2 Connect, Fastrak, RAM, SAP 2000...
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,136
    06:33 AM
    Don't know about the other programs, but for revit the GTX series are excellent.
    I have a 3GB GTX580 and it is way overkill for revit but lovely for gpu rendering. For revit, I had previously worked very happily with a GTX480 - probably around $60.00 these days.
    With the change, i might choose to get a better cpu / motherboard or upgrade the RAM.
    Member need4mospd's Avatar
    March 2, 2011
    Houston
    445
    03:33 PM
    I've found the benchmarks on this site to be quite helpful when building new machines:
    PassMark Software - Video Card Benchmarks - High End Video Cards
    The GTX 480 would be my first choice. And it would perform significantly better than the most expensive "cad" card option for 1/3 of the price.
    Coeur d Alene, ID
    2,732
    01:33 PM
    We've gone mostly Quadro 2000's.....shop around though, we got way better deals on them than what your showing...
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,019
    03:33 PM
    I have no clue, but I'm running a Quadro 2000 along with a Quadro FX 4800, and I've had nothing but problems. I've tried several drivers. I guess I need to try more. Not sure if it's the cards or what, but it's a major PITA.
    I'd get the new GTX 690 card with the keplar architecture. Nobody's running it with revit yet that I know of, but someone needs to be the first!
    Alex Cunningham likes this.
    Coeur d Alene, ID
    2,732
    01:33 PM
    Quote Originally Posted by dzatto View Post
    Think your issue is trying to use two different generations of Quadro's at the same time...Personally I would pull the FX out...it uses double the power the 2000 uses...
    Member Mike Ferrell's Avatar
    London, Ontario, Canada
    53
    04:33 PM
    We tried the Quadro FX 1800 "professional" card and then moved to the GTX 560 Ti "gamer" card. The GTX kicks the Quadro card around the block. The GTX also works for the Cuda GPU processing with some of the Adobe programs for extra processing power as well. And it was less than half the price of the Quadro.
    I know the GTX isn't on the official Autodesk list. But it works great with Revit.
    Member willsud's Avatar
    December 13, 2010
    Ambleside, Lake District, UK
    441
    09:33 PM
    I think I saw mentioned in the 3dsMax Area forum that iRay isn't enabled for keplar yet but should be er, interesting
    Mind you, just my view, I'd never buy a GTX card - I'll wait for the Quadro version.
    Edit:
    Of course I'm referring to the Ray Trace feature in Revit 2013 which I believe is iRay
  1. Video Card Drivers
    By cellophane in forum Hardware and Infrastructure
    Last Post: February 22nd, 2012, 04:06 PM
  2. Replies: 0
    Last Post: January 20th, 2012, 12:45 AM
  3. Radeon Graphics Card??
    By vandelay in forum Hardware and Infrastructure
    Last Post: November 29th, 2011, 06:03 PM
  4. ATI Video card not working well.
    By Wadeshuey in forum Hardware and Infrastructure
    Last Post: April 22nd, 2011, 04:04 AM
  5. can/should I add a graphic card to my comuter?
    By hagit in forum Hardware and Infrastructure
    Last Post: February 25th, 2011, 07:21 PM
