Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Results 1 to 8 of 8
Like Tree5Likes
  • 1 Post By Andrew P
  • 1 Post By snowyweston
  • 2 Post By snowyweston
  • 1 Post By cerb0z
Thread: Open Revit file in Illustrator
    Vik
    Vik is offline
    March 27, 2012
    52
    09:33 AM
    Hey, I am trying to open my Elevation view from Revit in Illustrator.
    I tried all the export formats but my CS5 recognized none of them.
    Did anyone have same problem?
    Member Andrew P's Avatar
    February 19, 2011
    314
    08:33 AM
    You can either create a PDF which is imho the best option, or export to DWG 2004. llustrator doesn't recognize dwg 2010.
    Vik likes this.
    December 21, 2010
    C.LONDON
    3,385
    09:33 AM
    An .eps export (or similar) should definately be on the wishlist - there's some argument presentation work can sit within Revit, but there's still somethings better suited to being done outside of it.
    Out of interest, what are you trying to achieve?
    Vik
    Vik is offline
    March 27, 2012
    52
    09:33 AM
    I had a look on Google what is .eps and it seams that what i am looking for. Thanks a lot. I did download driver but it is not appearing in my Print to ....window.
    Can you please suggest me website for the revit to .eps format converter.
    I would be happy to do all my presentation drawings in Revit but I'm new to the program and for me Illustrator is a shot cut. If you can suggest some tutorials on this subject, I would love to find my way around Revit without bouncing files between Adobe Suite. Usually I will have 2D, 3D in Revit and then adding color and details in Photoshop but quality of jpg is not that sharp as pdf. After Photoshop, files going to InDesign were I lay them out and adding some text.
    If you have an idea how I can do it all in Revet, let me know please, it will save me lots of time.
    December 21, 2010
    C.LONDON
    3,385
    09:33 AM
    Quote Originally Posted by Vik View Post
    Without it being a native option I've never looked too far into it personally, but it's certainly something I used to do many moons ago with Autocad before M-Color made hatching a more tolerable process, before Autodesk saw sense and improved things, all in catch up with Bentley... so :
    I'm afraid not, sorry.
    Clearly, the mileage you'll get out of Revit's graphical capabilities will vary on the effort you put in and whether or not putting that effort in, against your standard workflows, is worth it. Obviously, the "WIN" is that the more work you keep native, the more that will follow your model development, and limit setup-work in your complimentrary software. Good blogs to check out? Off the top of my head you want to track down Jason Grant & David Light's "Presentations that POP" from the AU (Autodesk University) lecture - it comes with datasets (models and whatnot) and some good howto/idea guides.... another one is Jeffery McGrew (sp?) - I think - who drops by now and then here as it goes - who's got a very nice render/composite cross-breed style to play with...
    Yes, working with rasterised images is a pain, and having vector graphics come out of Revit would be nice. If you've Autocad you can go via that (Export Revit to .dwg then to .eps) for far cleaner linework - and far lighter than a .pdf (or at least it was in the years when I used to do that. If you are doing a lot of post-processing then trying to get it all done in Revit will probably not suit my next suggestion - drop InDesign altogether and compile presentation sheets in Revit - but since Revit's still got fairly limited DTP abilities (OOTB text objects and crop boxes suck) then you'll still have to generate standalones.... and clearly, if you've a team competent in InDesign, but not Revit, then you've got to play to your team strengths.
    I'll have a fish around my bookmarks after I've posted this.
    Vik likes this.
    December 21, 2010
    C.LONDON
    3,385
    09:33 AM
    Here's the best of the bunch (for what I imagine you're trying to achieve) at Jason Grant's blog
    HERE
    I can't find Jeffery's just yet... I may have got my bloggers mixed up...
    But another two I forgot to mention :
    Peter McCarthy's provides some good reading/viewing on standard Revit presentation functionality HERE
    as does Andy Milburn in his GAJ blog HERE
    ...you'd also do well to dig around here, a fair few discussions on graphics (more renders than presentation mind) like this one HERE
    EDIT#2
    It wasn't our Jeffery, it was a chap called Jereme... still, I think this is still one of the best examples posted on the web of composite workflows between Revit & Photoshop (that I've found) CHECK IT OUT HERE
    One technique that isn't discussed in any of these, and for me is key to speeding things up, is you can do away with wand selection for mask creation in P'Shop altogether by creating multiple duplicates of your view - where by you override elements and categories en masse with solid fills - then export those out and compile as layers. I only play with VIZ, I don't "do" it - so apologies if that's not the best description - but it's the best I can do!
    Last edited by snowyweston; April 29th, 2012 at 07:50 PM. Reason: dodgy hyperlinks
    Vik and Darryl_S like this.
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    243
    11:33 AM
    Shades of Grey - this blog is also has some great presentation posts.
    Edit: oops, should have f5 before posting, sry.
    Vik likes this.
    Vik
    Vik is offline
    March 27, 2012
    52
    09:33 AM
    Thank you snowyweson and cerboz, there is lots of useful info , of to go through all this exiting tutorials, this is exactly what I was looking for and even more.
    All the best !
  1. What Revit Wants: Open Source BIM software at osbim.org
    By luke.johnson in forum Blog Feeds
    Last Post: November 14th, 2011, 01:15 AM
  2. Opening a new file opens up a new session of revit, despite already having Revit Open
    By Scott_CJDH in forum Architecture and General Revit Questions
    Last Post: September 22nd, 2011, 08:43 AM
  3. David Light: An open Revit Standard?
    By David Light Blog in forum Blog Feeds
    Last Post: July 9th, 2011, 08:00 PM
  4. Can someone do me a favor and try to open a recent file while in perspective view?
    By DoTheBIM in forum Architecture and General Revit Questions
    Last Post: June 26th, 2011, 12:26 PM
  5. Can't open project file
    Last Post: June 24th, 2011, 09:51 PM
