Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree4Likes
Thread: Splitting up a model
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,551
    03:00 AM
    I have a project that has 3 buildings. We inherited this project from another firm, the project is around the 50% Design Development mark.
    What would be the best way of breaking up the project into 3 projects, each project with 1 building from the original project?
    I was thinking of making 3 copies of the project and deleting the buildings that do not need to be in each file.
    Ideas? Recommendations? Issues?
    Orlando, FL, USA | info@planta1.com
    2,788
    06:00 AM
    Select objects for building A > Group > name as "Building A" > from the group panel, select "Link" > "Replace with a new project file" > Revit offers to name the file as 'same as group name' , accept with "Save". Now "Building A" is a link in the original overall project. Then repeat steps for building B and C. At the end, Manage > Manage links will show you the 3 files as links, and now you have each building in its own individual Revit project file.
    December 8, 2010
    Northern California
    3,551
    03:00 AM
    FREAKING AWESOME!!!! Once again you teach me something I never even knew existed. Nifty little tool.
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    568
    06:00 AM
    WOW! Awesome tip Alfredo, I never knew this existed either +REP
    JTB
    JTB is offline
    Member JTB's Avatar
    December 30, 2010
    Athens, Greece
    124
    01:00 PM
    Quote Originally Posted by JCM View Post
    +1! Very useful, thanks a lot!!!
    This can be used for a building and a site surface too!!!
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    10:00 AM
    Great tip Alfredo! More rep for you...
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    3,309
    03:00 AM
    that is a cool tip! Along the same lines, I have a project that I created all of my scope of work on a workset in the Architect's model (not linked, the actual model). I know now that this is probably not the best way to do this. I have just received a new Architect's model with several changes and I need to get my workset scope out of the old model and into the new model but this time I will link the Architect's model. I think that the above workflow will give me what I need to create a separate model file with only my scope of work that I can then link the Arch model into. Does that make sense?
    2,788
    06:00 AM
    Quote Originally Posted by Dave Jones View Post
    ...I think that the above workflow will give me what I need to create a separate model file with only my scope of work that I can then link the Arch model into. Does that make sense?
    Yes, actually, this technique might be very useful for you, to separate the rest of the model from your scope of work in the building.
    7,101
    05:00 AM
    Its an awesome way to convert a building to a Link, but there is a MAJOR thing you need to be careful with:
    Depending on how youre going to document that "Linked Model," you might be very very annoyed when you realize that converting a Group to a Link doesnt actually use a Template File. Many Many Many settings pertaining to File links "say" By Host View, but that DOES NOT mean "use the setting in the parent file," it means "Find a setting in the link that has the same name as the one in the parent file." True story. Plus, since it wasnt created in your template, its not going to have any of your standards, your components, your details, your views, etc.
    So, if youre going the Linked View way, youre in a world of hurt. If youre going to document everything in the Main Model (parent), you are slightly better off... Except in 2011 you cant tag Linked Rooms.
    So you have a few options: You can then try to ram a blank project underneath the new Bare Link file, by Binding THAT file in to a new file you started with your template, but then you have issues with disassociated levels from the views. Or, you can go your original road, and do a save as a few times.
    My advice: Do the save as a few times, but do it right:
    1. Save as, save as, save as.
    2. In the Links, blow away all of the sheets (not views) and delete all the titleblocks, so no one gets confused about what the master file is (assuming youre going BLV).
    3. Pick up and MOVE the models (and all the views, and annotations, etc), so they are at a sensible origin, and establish Shared Coordinates the right way. (Otherwise, since they all started out as the same file, you can link them in origin to origin, but since its not the right way to do it (in my opinion), i dont do that).
    4. Link them in fresh, and go to town on your view templates. Copy/Monitor the Linked Grids, since youll end up wanting them in the Overall plans, in the native model (but in the building plans youll want them in the linked model, so they need to stay there too).
    5. Explain to the team how to control and Name the views in the Links that correspond to the views in the Parent file, and have a ball.
    4
    February 2, 2015
    1
    04:00 AM
    I've just tried to convert a group to a linked file and it will not work. Any suggestions as to why?
    I believe I've followed these instructions exactly. I created the group, used the link button, gave the file a name, it acts like it's processing but then when it's done it's still a group and not a linked file.
  1. Model management: review the model??
    By jbenoit44 in forum Coordination Tools
    Last Post: May 12th, 2011, 12:15 PM
  2. Printing host model with linked model
    By IMCarter in forum Structure - General Questions
    Last Post: May 11th, 2011, 01:00 AM
  3. Splitting wall section horizontally
    Last Post: May 6th, 2011, 06:32 PM
  4. Model Entry Gate Far Away From Main Model
    Last Post: April 26th, 2011, 05:29 PM
  5. Compare the old model to the new model?
    Last Post: March 29th, 2011, 06:20 AM
Tags for this Thread
