Results 1 to 3 of 3
Thread: Lost transparency, png-images
    December 17, 2010
    Denmark
    2
    11:30 PM
    Why did trees, inserted as images in elevations, suddenly loos their transparency? If I insert the same image again (png), the background is transparent as expected.
    I know that the trees in my garden will loos their transparency in a month or two, but that's not Revit :-)
    Søren
    December 13, 2010
    Ambleside, Lake District, UK
    592
    09:30 PM
    Just a first thought would be - is the .png image set to foreground or background in the options bar?
    You probably know this, but just in case, if not in the foreground the image and transparency will not display in front of model objects in a View.
    William
    December 17, 2010
    Denmark
    2
    11:30 PM
    The .png is set to foreground.
    Søren
  1. Lost room in plan
    Last Post: June 17th, 2015, 05:00 AM
  2. 2012 Kills the Elevation Mass Transparency Workaround?
    By luke.johnson in forum Architecture and General Revit Questions
    Last Post: June 30th, 2011, 01:00 AM
  3. Lost without you!!!
    By LeanneZ in forum Out There
    Last Post: March 22nd, 2011, 08:03 PM
  4. Lost Sheet
    Last Post: March 1st, 2011, 09:04 PM
  5. Infrastructure / Transparency
    By Munkholm in forum Forum Suggestions and Feedback
    Last Post: January 8th, 2011, 01:28 PM
Tags for this Thread
