Donate Now Goal amount for this year: 3000 USD, Received: 2139 USD (71%)
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By edwinguerra
Thread: How to delete imported Cad file permanently ?
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    740
    11:02 PM
    Hi,just wondering How can i delete the imported cad file (DWG,Sketchup) permanently means it did not exist inside project ?
    it is not linked it is imported.
    I need to delete it just we delete families from project browser.
    Kingdom of Denmark
    4,111
    01:02 AM
    Unless you also exploded it, you can just select the imported dwg and hit delete... If it's been exploded, you can "window select" everything, and use the filter option to select all the acad remains... But you'd still have a lot of cleaning up to do. The imported dwg will have left some Line Patterns, Line Styles, Fill Patterns and what not. That's the reason why you should always LINK a dwg, instead of importing it.
    April 25, 2011
    Egypt
    740
    11:02 PM
    Can i make it not even showing in imported family in visibility and graphics because when you hit delete even if you do not explode it , it is still there in imported families in visibilty and graphics?
    Also what i know about link it should update itself automatic mean any change in autocad should be followed in revit and that is what did not happen inside revit shall i restart revit to see this change ?
    Kingdom of Denmark
    4,111
    01:02 AM
    Nope, no restart required, you'll just need to reload the link from "Manage Links". And yes, imported DWG's can be turned off using V/G (for each view), by unchecking everything on the "Imported Categories" Tab.
    April 25, 2011
    Egypt
    740
    11:02 PM
    Thanks i do not know how to reload it !
    about imported categories what i want is not hiding it, i want to make it as i am not imported it because when you delete the imported category(Cad) and go to tab of imported families you will see layers and everything is exsiting there (it is like want to be sure that linked deleted file is not live inside revit anymore ).
    August 16, 2012
    1
    11:02 PM
    February 25, 2011
    5
    04:02 PM
    If you have subscription, get Model Review and install it. Then run it with one of the out of the box templates that detect imports. Then export to html, copy paste to Excel. Format offending element IDs with ";" separations and paste into Manage->Select by IDs then hit delete. Purge project and it should go away (purging sometimes requires a few runs ~3)
    BIM blog.ca
    gdoherty0102 likes this.
  1. topography surface created by imported file not visible in 3D view
    By anjata in forum Architecture and General Revit Questions
    Last Post: February 12th, 2012, 12:55 AM
  2. Replies: 0
    Last Post: August 24th, 2011, 10:30 AM
  3. filters - try to rename or delete
    By cjridder in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2011, 08:32 AM
  4. How to cut/delete finish layer?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 31st, 2011, 08:28 PM
  5. delete unused level datums?
    Last Post: April 23rd, 2011, 03:17 PM
