Results 1 to 8 of 8
Thread: Unloading a link...cannot be undone...
    December 21, 2011
    Atlanta, GA
    3
    07:21 PM
    Unloading a link cannot be undone. Do you want to continue?
    A little background. I am working in my file and want to open one of the consultant files. How should I open the file. Do I need to close out of Revit or just unload the link. To prevent closing out of the current file, I can save time by unloading the link, however, when I do Revit tells me, "Unloading a link cannot be undone. Do you want to continue?"
    Am I going about this all wrong. Is it neccesary to close the file I am working in first, or can I unload the revit link?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,163
    06:21 PM
    Yep. It's a pain in the arse, but I always just close out the current file.
    I think you can just open another version of Revit, but I haven't tested that yet. I'm not sure what will happen if you make changes and save it while it's linked in another session.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    4,670
    07:21 PM
    You can also open a new instance of Revit and open it there with no problems. There was another thread where this came up and Aaron had a fancy solution. Give me a few minutes and I'll find it for you.
    Should I split this site up?
    6,506
    06:21 PM
    Its a stupid warning that basically means nothing. Its not REMOVING the Link, its simply unloading it. Big deal. Go back in to Manage Links after the fact and hit Reload. No worries.
    If both are workshared, you can open locals of both files concurrently in one session.
    Otherwise, itll unload it and you can reload.
    Or, open it in another session of Revit. Bear in mind youll still need to Reload it in the original sessions, since SWC doesnt reload links.
    December 21, 2011
    Atlanta, GA
    3
    07:21 PM
    Thanks all...great advice
    August 9, 2011
    Louisville, KY
    4,670
    07:21 PM
    For some reason it never occured to me that it was unloading, not removing. I always opened a 2nd instance of Revit.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    1,679
    06:21 PM
    Late to the game, but - yeah - what Aaron said.
    The message is poorly worded. It does NOT mean that you can never Reload your Link again.
    What it really should say is:
    "Unloading a Link will flush your Undo history"
    You will not be able to use the Undo function to go back to Undo anything before you did the Unload.
    It doesn't completely break your Undo, either. It just resets it and starts over again from that point.
    Say you had done commands 1, 2, 3, 4, 5, 6, 7 and 8. At this point, you can undo 8, 7, 6, 5, 4, 3, 2, 1.
    If you didn't Undo or Unload, and just continued running more commands, you'd be doing 9, 10, 11, etc, which you could still Undo 11, 10, 9, 8, etc.
    However if after step 8 you did an Unload Link, your next command would start the Undo history all over again with 1.
    You could no longer undo 8, or anything before it.
    (Hope that didn't just make it more complicated!)
    But when you Unload a link
    dzatto's Avatar
    December 9, 2010
    5,163
    06:21 PM
    Just started unloading and reloading. Works great. Way way better than closing the project. Thanks guys!
  1. Revit Link - Link model from RAC to RST
    By JasonWallis in forum Structure - Interoperability
    Last Post: April 9th, 2012, 12:35 PM
  2. DB Link
    Last Post: December 19th, 2011, 04:12 PM
  3. Link Civil .dwg into RST?
    By LeanneZ in forum Structure - General Questions
    Last Post: December 9th, 2011, 06:21 PM
  4. Cad link
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: February 7th, 2011, 07:19 PM
  5. ETABS Link
    By engr_mondo in forum Structure - General Questions
    Last Post: January 9th, 2011, 11:49 PM
