Donate Now Goal amount for this year: 3000 USD, Received: 1448 USD (48%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Roof Framing - clipped truss
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    4,857
    07:59 PM
    One of these days I'll be able to answer questions instead of just asking...
    Anyhow - Not sure what the 'correct' or 'best' way to put together a roof is. I'm not quite sure how best to explain it - hopefully the image can do it for me. I believe it is a clipped / bob-tail truss and I'm unsure of how to handle the clipped portion above the wall. I know I could use a wall for the clip which I can host my EIFS sweep on but I'm not sure how that would translate in detailing.
    Thanks
    Attached Thumbnails Attached Thumbnails Roof Framing - clipped truss-roof-framing.jpg
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,173
    06:59 PM
    Thanks
    Hey, wait in line buddy!
    I'm not up to speed on trusses at all, but wouldn't that be modeled in your truss family? As for the EIFS, I ususally use the fascia tool and attach it to model lines. The fascia tool is pretty sweet once you get used to it.
    December 21, 2010
    Phoenix, AZ
    1,305
    04:59 PM
    Why use Fascia instead of Wall Sweep? I mean besides the fact that, in this case, it's a fascia...
    dzatto's Avatar
    December 9, 2010
    5,173
    06:59 PM
    The main reason I use fascial is because a wall sweep is only horizontal. What if it's a gable end? Fascia FTW!
    August 9, 2011
    Louisville, KY
    4,857
    07:59 PM
    I'm not worried about the truss itself in the model since other than sections it won't appear and it can just be drawn there. I don't know how to deal with the wall to roof condition in the model. Normally the roof slopes down and bears on the wall, which if not clipped would be a few more feet farther out.
    The roof finish is +/- 24" above the top of the wall and rests on the clipped truss with some misc. framing for the fascia. Applying the fascia sweep isn't a problem either - I know how to do that. What I don't know is how to get the roof finish surface at the level it should be with some appropriate framing between the wall and roof. Does that make sense? I appologize if I'm not being clear - it's hard to explain via text & images sometimes.
    Attached Thumbnails Attached Thumbnails Roof Framing - clipped truss-roof-framing-2.jpg
    dzatto's Avatar
    December 9, 2010
    5,173
    06:59 PM
    That's where you are losing me. Won't that area be made up as part of the truss? When they build it, they'll slap on the trusses, put on a fascia board to cover the ends, then apply the EIFS. Or am I way off base here?
    I'm thinking make the truss, which will include the 24" area. Put it in your model. Put in 2 fascias, one for the sheathing that will cover the ends, and one for the EIFS. Slap on the roof and have a beer. No?
    December 21, 2010
    Phoenix, AZ
    1,305
    04:59 PM
    So this is a construction question and not a Revit question?
    If so I think I'd continue the wall framing up into the area but I don't honestly know if you need anything in there other than misc. framing for the fascia.
    August 9, 2011
    Louisville, KY
    4,857
    07:59 PM
    It's a Revit question. I know how it will be built but I'm unsure of the 'model it the way it will be built' solution. I'm most likely overthinking it all. I'll slap in a stud wall between the masonry wall & roof and call it a day.
    Thanks for the help. One of these days I'll figure it all out.
    Kingdom of Denmark
    4,109
    01:59 AM
    If I understand you right, you just need to unlock the finish layer of the wall and give it a Top Extension Distance of 24" - See attached.
    Attached Thumbnails Attached Thumbnails Roof Framing - clipped truss-top-extension.jpg   Roof Framing - clipped truss-unlock-layer.jpg
    dzatto's Avatar
    December 9, 2010
    5,173
    06:59 PM
    That won't work either, because the 24" area is at an angle where the finish layer is. I still say it's a truss on the wall, so model a truss with the extra framing. Cap the openings between the trusses, and apply the EIFS fascia.
  1. structural framing tag
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 05:59 PM
  2. Calculate Roof Area for Slope Glazing roof
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: October 31st, 2011, 05:54 PM
  3. Replies: 1
    Last Post: May 23rd, 2011, 02:28 PM
  4. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 05:48 AM
  5. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
