Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree2Likes
Thread: Creating Fences
    November 22, 2011
    17
    04:03 AM
    Creating Fences
    Is there anyone who knows how to create fences, or where I might import on from.
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    134
    04:03 AM
    I just use the railings tool to make fences.
    Moderator mark b's Avatar
    NSW Australia
    1,414
    11:03 PM
    In your default family file there should be a folder called "Sample Files" inside there a Rvt. file called fences (these are railings). Open it up pick one you like Copy/Paste into your project, this will give you another "Railing Type" in your railing drop down list, draw as railing.
    ArchTech247 likes this.
    Member biff's Avatar
    June 13, 2011
    Australia
    480
    11:03 PM
    I made a few with the structural beam system tool on a vertical work plane. Works a treat, and you can cut the profile to follow the topo.
    Then use the coping tool for railing to post clearance for the pedantic.
    cheers
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,143
    10:03 PM
    Given the problems with railings (cannot host to topo), I tend to use curtain walls so that I can edit the top and bottom profiles.
    NSW Australia
    1,414
    11:03 PM
    Quote Originally Posted by biff View Post
    cheers
    You mean like this
    June 13, 2011
    Australia
    480
    11:03 PM
    Yep, just like that Mark. I had forgotten this was where I found out how to do that. Kudos to you, mate.
    December 21, 2010
    C.LONDON
    3,425
    12:03 PM
    Quote Originally Posted by Ian.Kidston View Post
    I'm pretty sure you can!?
    1,143
    10:03 PM
    Unless a major change has snuck through, I am pretty sure that the only elements which will host railings are floors, stairs and ramps.
    Before I switched to curtain walls, I remember trialing the option of putting a thin floor under the topo to host the railing on - Way too much work and you still ended up with railings which is not the best tool in revit's kit bag in any event. For picket fences, Mark's structual beam methodology works well. I have a curtain wall set up in my template for putting up a generic pailing fence for shadows etc
    7,325
    06:03 AM
    +1. We use curtain walls for them as well. Much easier to have gates as Curtain panels, than as balusters or entirely one-off family solutions.
  1. Creating Perspective View
    By Chang Lee in forum Architecture and General Revit Questions
    Last Post: March 4th, 2016, 06:15 PM
  2. Creating Haunching (Urgent)
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: November 17th, 2011, 09:07 AM
  3. Creating Views
    By cwwalder in forum MEP - General
    Last Post: February 9th, 2011, 06:51 PM
  4. Creating views
    Last Post: January 18th, 2011, 04:24 PM
  5. Creating Section causes Regens
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: December 30th, 2010, 08:34 PM
