Donate Now Goal amount for this year: 3000 USD, Received: 1975 USD (66%)
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By engel_hg
Thread: Cad drawings to revit line drawings
    October 26, 2011
    7
    08:16 PM
    How would I import a CAD drawing and convert it to a line drawing in revit? I want to import the CAD drawing and take call outs from it. When I import the drawing into a drafting view, and then take a call out of the a specific section, nothing shows up in the call out. Is this even possible to do in Revit?
    October 26, 2011
    7
    08:16 PM
    I have already tried to explode the CAD file, but there are too many "instances" to explode.
    6,920
    09:16 PM
    If youve been exploding CAD DWG's in your Revit model, that model is going to be completely screwed later. What is it a drawing of?
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    740
    02:16 AM
    there is better idea, possibly you have a little lines and although that the programme tell you when you explode it there is too many lines so the solution for this is inside cad itself
    - just select the drawing intending for importing it in revit and make ctrl+c
    - paste it in new empty cad file.
    - then import it in another empty revit file (not within your revit project because if you did that you will definitly will slow your performance).
    -after you imported it into another empty revit file explode it convert it into revit lines , get rid of cad lines if it is possible and noting that. if your lines is more than 10,000 lines revit will not explode,however if you have possibilty not to explode it and you need just few lines ,it is better to use pick lines and then tab .
    that what i am usually do and ask other members i complained a lot in this inside forum. but memebrs here have good advices.
    October 22, 2011
    Budapest, Hungary
    47
    04:16 AM
    I usually convert dwg details to revit detail falmilies, like window details, curtain wall details, and i do it like ahmed said. Its not a good idea to import it directly your model, it will create a lot of linestyles btw...
    And what about this "line is too short" problem? Will it be solved, or it remains revit's defect?
    Junior Member engel_hg's Avatar
    October 9, 2011
    Manila,Philippines
    48
    10:16 AM
    Hi guy's. well regarding on this matter. importing detail to Revit. we need to considered the following.
    1. first is the scale and unit or your cad file.
    2. Layer
    3. you most isolate only the detail that you need to export.
    4. hatch pattern
    Now workflow and template, in my practice first thing is to do is to wblock the detail that i need or if the detail is already separeted much better you just need to check the Layer and purge it and save, also i suggest to run the command "overkill" to delete the overlapping lines in autocad.
    then when you done all that in Cad go to revit. open new project from "view" create new "drafting view" after that insert the cad detail go to insert tab then import cad. double check the following on the insert dialog box
    - Color:Preserve or Black and white
    - Layers: Visible
    - Import Units: (units of your autocad)
    then once imported Verify dimension if correct before exploding. if correct hit the "full explode" after exploding some line that are below 0.8 in mm will be deleted. check now all the line if correct,you most purge it to have a clean detail.
    now just save your Detail go to "menu"/save as/library/view select the name of the detail you want to save in your library
    for me i compile all my detail in one single revit file see image below.
    lucis29 and tinxo86 like this.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    02:16 AM
    Quote Originally Posted by Nathaniel101789 View Post
    DO NOT EVER EXPLODE DWG'S IN REVIT. It will totally f**k up your project.
    Here's a workflow to create callouts from a dwg:
    1. Import / Link cad file in a MODEL view. Keep in mind that you need to uncheck "Visible in this view only" from the import menu.
    2. Create Callouts and you should be fine.
    The one suggested by engel_hg is better, since it leaves all redundant crap out. However, for correct placement in Revit I suggest you move the Autocad UCS to the intended wblock basepoint before creating / exporting the wblock. This will not affect the placement in drafting views but will affect placement in model views...
    But in all fairness: just don't do it.
    Use them as underlay to create native revit detail components. Preferably parametric but not necessary. Upside is you can always do that later. Compile native revit detail components which you can place in model views. Done correctly you can adjust any standard detail to project environment in a few clicks. You'll gain all the time needed to manually coordinate and update those pesky line thingies.
  1. Is it possible to do MEP drawings in Revit Architecture software?
    By rohini in forum Architecture and General Revit Questions
    Last Post: November 2nd, 2011, 01:50 PM
  2. Referencing Revit models in Autocad drawings
    By Nick Kane in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 04:39 PM
  3. Workflow for drawings
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: June 25th, 2011, 06:31 PM
  4. Marketing Drawings:
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: June 3rd, 2011, 02:07 AM
  5. Markup revit drawings in real-time for live presentations?
    By iru69 in forum Coordination Tools
    Last Post: February 23rd, 2011, 06:17 PM
Tags for this Thread
