Donate Now Goal amount for this year: 3000 USD, Received: 1448 USD (48%)
Results 1 to 8 of 8
Thread: Beams are not visibel
    jhn
    jhn is offline
    June 15, 2011
    Denmark
    5
    10:41 PM
    Hey again.
    I am new to Revit.
    I have a problem I hope that someone can help.
    I can't see my beams in plan veiw. They are only seen in section veiw.
    does anyone have a possible solution.
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    740
    08:41 PM
    i think beams supposed to be in ceiling floor plan not in normal floor plan, if you want to show it in floor plan just check view range make its height greater like 2 meter.
    December 12, 2010
    New York
    322
    11:41 PM
    Post a screenshot.
    jhn
    jhn is offline
    June 15, 2011
    Denmark
    5
    10:41 PM
    Quote Originally Posted by ahmed_hassan View Post
    No it's not that
    Junior Member engel_hg's Avatar
    October 9, 2011
    Manila,Philippines
    48
    04:41 AM
    Ok beams are below the level to be able to see it you most adjust your view range "view depth" setting.
    Beams are not visibel-view-range.jpg Beams are not visibel-beam-1.jpgBeams are not visibel-beam-show.jpg
    in addition i add beam at -600 below the level 1 to be able to see it i need to adjust my view depth to -700
    or try to check your visibility setting maybe structural framing is off.
    jhn
    jhn is offline
    June 15, 2011
    Denmark
    5
    10:41 PM
    I have tried it what you writing, it just dosn't works.
    The beam is only visible if I put the cut plane offset to cut through the beam 2600 mm above the floor. This means simply that the rest does not appear correct. I want the bar to show up as hidden lines over cutplane, so I can keep cutplane of 1200 mm.Beams are not visibel-cut-plane-1200-mm.jpgBeams are not visibel-cut-section.jpgBeams are not visibel-cut-plane-2600-mm.jpg
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    08:41 PM
    Set the cutplane to 2600mm, use the Linework tool to override Beam visibility and set the Cutplane back to 1200mm.
    You should keep seeing the Linework.
    If this doesn't work, create a duplicate view from the level above. Set the viewrange so that you see the beams
    Use as Underlay in the view you need to see the beam, and use Linework to show the beam. Turn the underlay off again.
    United States
    1,132
    02:41 PM
    So you have a plan that you want to see beams in. Go to 3D and orient that 3D to that view. If you can not see your beams in 3D adjust your section box until you can. This will tell you where your view ranges need to be.
    If when you orient you can see your beams, then you have a VG setting or something is covering up your beams (IE a floor), but your 3D view should also show you if there is something in the way of your beams.
  1. Playing Around with Tapered Beams
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: April 7th, 2014, 10:32 AM
  2. Connecting 2 concrete beams
    By Robin Deurloo in forum Architecture and General Revit Questions
    Last Post: October 12th, 2011, 07:49 PM
  3. Curved beams in elevation
    By alexsasu in forum Structure - General Questions
    Last Post: July 1st, 2011, 03:30 AM
  4. Placing beams - best practice
    By DD1 in forum Structure - General Questions
    Last Post: June 25th, 2011, 06:21 AM
  5. Beams and Stacked Walls
    Last Post: April 19th, 2011, 07:11 PM
