Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree1Likes
Thread: beam-column connection
    October 22, 2011
    85
    09:56 PM
    hi, how to connect this two beam to the column. i tried several methods, the trim tool, or dragging the endpoint component of the beams.. but still i cannot connect the two beams to the column seamingly... is there any other method? thanks guys.. pls see my attached file. tnx.
    Attached Thumbnails Attached Thumbnails beam-column connection-connection.jpg
    Junior Member engel_hg's Avatar
    October 9, 2011
    Manila,Philippines
    48
    09:56 PM
    Trim first the two wall then join then with the column using "Join geometry" under Modify panel
    October 22, 2011
    85
    09:56 PM
    hi engel_hg, i cannot do that mainly because that is not wall. that is a beam. so, how will we connect the two beams to the column? tnx for the response.
    October 9, 2011
    Manila,Philippines
    48
    09:56 PM
    Quote Originally Posted by r7_human8y View Post
    Ahh i see i thought its a wall, well as far as i know. structural beam are automatically connected to column once they attached to each other. Or just create model in place structural framing then joint it to the column to make it seamless to fill in the gap.
    But make sure that you use all same material with beam column and the model you will going make to fill in the gap.
    October 22, 2011
    85
    09:56 PM
    hi engel_hg, thanks again for the response... once i create a model in place as structural framing, can i determine it in the schedule that, that is the two beams i created? tnx a lot man.
    October 9, 2011
    Manila,Philippines
    48
    09:56 PM
    Well that the problem because model-in place will not appear on the schedule. that's why you will just going create a small extrusion to fill in the void gap.
    Orlando, FL, USA | [email protected]
    2,787
    08:56 AM
    If you already tried with the Trim by Corner tool, and you tried dragging the endpoints of the beams to the center of the column, and the beams still don't connect, I suspect that the beams are not at the same elevation. Can you provide a screen capture in 3D?
    Alex Cunningham likes this.
    October 22, 2011
    85
    09:56 PM
    hi alfredo, this is the 3d view... pls see the attached file. tnx again.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    01:56 PM
    I think you need to use the Coping tool for this (on the Modify tab). To extend the beams, select them and change the cutback value in the Properties. Or select the blue arrows in Plan View and drag them to a new position.
    Moderator gaby424's Avatar
    December 11, 2010
    907
    03:56 PM
    also check if the column family doesn`t have some reference planes offseted from the geometry in the plan view(delete them or make them not to be a reference).
  1. Column and Beam Issue. Is it possible?
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 10th, 2011, 12:06 AM
  2. Beam Connection
    By PijPiwo in forum Architecture and General Revit Questions
    Last Post: August 18th, 2011, 10:09 PM
  3. Wall connection
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 27th, 2011, 03:46 PM
  4. beam/column join to create "rigid frame"
    By Scott Webb in forum Structure - General Questions
    Last Post: April 28th, 2011, 06:29 PM
  5. Slanted Column to a beam intersection - detail lines
    By jh75 in forum Structure - General Questions
    Last Post: April 14th, 2011, 02:23 AM
