Donate Now Goal amount for this year: 3000 USD, Received: 1130 USD (38%)
Results 1 to 4 of 4
Thread: REVIT.pat file
    March 31, 2011
    38
    10:32 AM
    REVIT.pat file
    I am having trouble understanding / finding where the hatch patterns are located. I added a hatch pattern to my REVIT.pat but it did not show up in my project file.
    I created a new .pat file for this one new hatch pattern and was able to create a new hatch in my project file by importing this new .pat file. This process did not add anything to my revit.pat file.
    How do I get multiple hatches into a project file
    1,241
    09:32 AM
    The .pat files are located here: ( RAC 2012 )
    C:\Program Files\Autodesk\Revit Architecture 2012\Data
    You can load a custom fill pattern here:REVIT.pat file-fill-patterns.jpg
    Moderator MPwuzhere's Avatar
    Coeur d Alene, ID
    1,581
    07:32 AM
    To get multiple "patterns" you have to transfer them from another project....else you can only add them one at a time by importing them. Just adding them to the Revit.pat does not add them to the project. Personally I like to create my own and leave the revit.pat untouched.
    (In case the coffee didn't kick in and I accidentally erase all the instructions and save)
    The default location for the revit.pat and revit metric.pat is \Program Files\Autodesk\Revit Architecture xxxx\Data
    March 31, 2011
    38
    10:32 AM
    Thanks, had not thought about "transferring" from another project.
  1. Dispelling the misconception about File Size and File Performance
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: September 24th, 2012, 08:34 PM
  2. Standalone Rvt file to worksharing file issue
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: October 18th, 2011, 04:12 PM
  3. Opening a new file opens up a new session of revit, despite already having Revit Open
    By Scott_CJDH in forum Architecture and General Revit Questions
    Last Post: September 22nd, 2011, 08:43 AM
  4. Replies: 0
    Last Post: August 24th, 2011, 10:30 AM
  5. Replies: 0
    Last Post: July 21st, 2011, 02:01 AM
