Results 1 to 7 of 7
Thread: Is it possible to create curtain wall with arc top and make the mullions arced?
    October 20, 2011
    Armenia
    41
    10:21 AM
    Revit Version(s)
    RAC2012
    Exclamation Is it possible to create curtain wall with arc top and make the mullions arced?
    Hi everyone!!!
    I tried to create a huge window with arc top by curtain system but when I tried to put mullions on the grid I found out that the top arc mullions attached straight from corner to corner. Is it possible to create curtain wall with arc top and make the mullions follow the curvature of the arc?
    MY FIRST THREAD
    Mr. Revit OpEd
    309
    09:21 PM
    Revit Version(s)
    All Revit
    It should be possible. If you are trying to create a "window" using a curtain wall then sketch one over the "hosting" wall. Make sure that the curtain wall type (Curtain Wall 1 in the stock template) is using the Automatically Embed parameter (check box). When you sketch the wall over the other wall it will cut a hole for it automatically. Select the new wall and adjust it so it's the size you want then click the Edit Profile button. You'll be able to alter the sketch of the wall to use an arc for the top instead. When you finish editing the profile you'll get a new shape that matches. Just apply curtain grids and mullions to wrap it up. It could look something like this. (left image)
    It is also possible to cut a host wall using Cut Geometry, pick the host first and then the hosted wall that should cut the host (assuming you don't like the Automatically Embed concept). It works for any wall on a wall. See the second image (on the right). Smaller 4" brick wall is cutting the larger wall to create the niche. The smaller wall(s) are also hosting the windows
    Attached Thumbnails Attached Thumbnails Is it possible to create curtain wall with arc top and make the mullions arced?-cw-round-top-01.jpg   Is it possible to create curtain wall with arc top and make the mullions arced?-cw-round-top-03.jpg
    Mr. Revit OpEd
    309
    09:21 PM
    Revit Version(s)
    All Revit
    It is also possible to create something like in the attached image. To make this one I created a rectangle curtain wall first. I copied it to clipboard before editing. Then I used the same Edit Profile approach to alter its shape. After finishing the first one, I used Paste Aligned - Paste to Same Place to put the original curtain wall back on top of the existing one. I select the new one and use Edit Profile again. Repeat until all the pieces are in place. I did this twice, the wall in the image is three curtain walls that share common edges.
    Last I put some curtain grids in and applied mullions. Look closely and you'll see some mullions that are not very happy with their situation. To clean this up I'd probable resort to in place modeling and delete the mullions that don't work.
    Attached Thumbnails Attached Thumbnails Is it possible to create curtain wall with arc top and make the mullions arced?-cw-round-top-02.jpg
    October 20, 2011
    Armenia
    41
    10:21 AM
    Revit Version(s)
    RAC2012
    Quote Originally Posted by Steve_Stafford View Post
    I don't understand "stock template" part with "Curtain Wall 1" type where can I find it? Cause I tried with Simple Curtain wall it didn't work out. There is no option of Embedding
    I am NOT a Revit tutor! Dave Jones's Avatar
    882
    09:21 PM
    Revit Version(s)
    RAC 2012
    Quote Originally Posted by spotless View Post
    this from RAC 2012 Imperial: C:\ProgramData\Autodesk\RAC 2012\Templates\US Imperial\default.rte then Home/Wall and in the Type Properties download there will be a Curtain Wall 1. Select Curtain Wall 1 and hit the Edit Type button and check the box for Automatically Embed.
    Will be a tutor someday...
    Revit Arch 2012 Win 7 Pro 64 bit
    Intel I7-860 @2.8GHz
    12GB DDR3 RAM GeForce GTX260
    Mr. Revit OpEd
    309
    09:21 PM
    Revit Version(s)
    All Revit
    Sorry, I failed to notice you are in Armenia when I replied earlier.
    In the metric template you'll probaby find just Curtain Wall as one of the three types of curtain walls you can use. The feature (parameter) I'm referring to is the Automatically Embed check box that will cause the curtain wall to cut into a host wall for you (see image). All curtain wall types in the template are the "same", they have the same parameters but each has different features selected in advance. The curtain wall type is the "dumbest", nothing much selected in advance while the Storefront type is the "smartest", it has more features set in advance.
    Attached Thumbnails Attached Thumbnails Is it possible to create curtain wall with arc top and make the mullions arced?-automaticallyembed.jpg
    October 20, 2011
    Armenia
    41
    10:21 AM
    Revit Version(s)
    RAC2012
    wow!!! it was so easy just like 1 2 3
    thank you very much, never thought that curtain wall types have difference in their properties, and I always used to avoid using Storefront one. thanks again
  1. How to make dome curtain wall in revit
    Last Post: October 26th, 2011, 10:25 PM
  2. Curtain System - Mullions out of line
    By R-Construction in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 5th, 2011, 10:19 PM
  3. make custom opening for curtain wall ?
    Last Post: September 26th, 2011, 04:19 PM
  4. Unparallel Curtain Wall Horizontal Mullions - Possible?
    By The Dropper in forum Architecture and General Revit Questions
    Last Post: June 28th, 2011, 09:04 PM
  5. Custom Curtain Wall Panels and Mullions:
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: June 9th, 2011, 05:26 PM
