Donate Now Goal amount for this year: 3000 USD, Received: 3122 USD (104%)
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree1Likes
Thread: Miter a steel tube?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    3,309
    04:32 PM
    Miter a steel tube?
    I don't work with steel shapes much but have a curtain wall mockup project that requires one steel tube davit support. It is a HSS6x6 tube vertical created from a column family with a HSS6x6 horizontal created from a structural framing family for attachment to the floor beam. In a project how would one miter these two sections?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,183
    06:32 PM
    Add a reference plane where you want the miter to be. Then use the cut tool. The only thing is, you can't delete the reference plane later. If you do the miter goes with it.
    Member Ben-May's Avatar
    December 8, 2010
    Melbourne,Oz
    305
    10:32 AM
    Reference plane will work, but as highlighted above it wont move with the member and is easy to delete accidentially. If you do use a ref plane, naming it something is a good tip to make sure later down the track you can easily see why it is there
    Depending how many instances you have, you are best to make a family which accurately includes both members as nested elements
    But if you only have a few instances, another method is opening by face on each element
    The good thing about opening by face is that it hosts to each member, and if you move the member the opening goes with it
    Orlando, FL, USA | info@planta1.com
    2,788
    07:32 PM
    Place the two tubes perpendicular to each other, maybe using coarse detail first so that they display as lines. Change to Medium detail. Now > Modify > Column/Beam Joins. You will see a couple of arrows close to the tubes. Click on one of the arrows > Lock the join > Modify to finish.
    See illustration.
    Attached Thumbnails Attached Thumbnails Miter a steel tube?-mitering-tubes.jpg
    Dave Jones's Avatar
    3,309
    04:32 PM
    Quote Originally Posted by dzatto View Post
    I tried a RP and it worked fine on the vertical tube but the horizontal tube leaves behind the wrong side no matter where I select it to start the Cut process. How do I control which side stays and which side leaves?
    Dave Jones's Avatar
    3,309
    04:32 PM
    See illustration.
    when I try this after selecting the Beam/Column Joins both my column and my beam are greyed out with no arrow to select ??
    dzatto's Avatar
    December 9, 2010
    5,183
    06:32 PM
    Quote Originally Posted by Dave Jones View Post
    I totally forgot about the way Alf posted. That would work best and is the easiest. I just started using that way a little while ago. lol
    Your post just beat mine. Maybe they have to both be beams or columns, not one of each?
    December 8, 2010
    Melbourne,Oz
    305
    10:32 AM
    Edit beam joins works well, when it works... Revit is pretty picky about how the beams are modelled and aligned. Generally it works well for beams at the same plane (the anyalytical line needs to be common)
    It doesnt work all that well for me for beam to column connections
    Dave Jones's Avatar
    3,309
    04:32 PM
    well, I've got a beam and a column so it seems that the RP method is the way to go. I finally got it to miter correctly by moving the short offending beam away from the column, moving the mitered beam and RP back in place, then mitering the column. PITA but it worked. I can see where the Column/Beam join would work well for beams in plan or columns in elevation but beams and columns don't like each other...
    2,788
    07:32 PM
    Yes, Ben and Dzatto are correct in their comments. Dave, since I had seen an image of that mock-up project you were doing, because you posted it in Augi some day, I thought about beam to beam connection, which is easy with the Column/Beam Join tool.
    But unfortunately, yes, it's not easy when it is column to beam. To make it work, the column element would have to be a beam that has been rotated (and disjoined) in elevation view, as in this example. Then the Column/Beam Joint tool works easily again, displaying the arrows!
    Strange things come out of that factory sometimes!
    Attached Thumbnails Attached Thumbnails Miter a steel tube?-miter-column-beam.jpg
  1. custom steel shapes
    By Scott Webb in forum Structure - General Questions
    Last Post: May 13th, 2011, 06:11 PM
  2. Miter detail components
    Last Post: April 20th, 2011, 11:01 PM
  3. Miter Curtain Wall Glazing
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: March 24th, 2011, 01:39 PM
  4. Rectangular structural steel section rotation?
    Last Post: January 18th, 2011, 05:53 PM
