Donate Now Goal amount for this year: 3000 USD, Received: 1160 USD (39%)
Results 1 to 8 of 8
Thread: Watermark
    Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    210
    02:32 PM
    Watermark
    Hi All,
    I can print my drawings to pdf and add a watermark in Acrobat (pic 1), but I wonder if watermark can be added in Revit, or if the text (letters) can be transparent, so everything behind is visible (pic 2). Thanks.
    Attached Thumbnails Attached Thumbnails Watermark-text1.jpg   Watermark-text2.jpg
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    07:32 PM
    Well, it can be:
    Create a drafting view
    Sketch the text using Filled Regions with a grey solid fill set to transparent.
    On you sheets, place this over the text and it should work.
    May 20, 2011
    Chicago, IL
    210
    02:32 PM
    ...yeah, I was thinking about it, ...eventually gave up on it as time consuming option, hoping for better more flexible solution - 'real' text that can be updated as needed. It looks like Acrobat is the way to go then.
    ...maybe in 2013
    Thanks Martijn
    Mr. Revit OpEd
    638
    12:32 PM
    Wrote a post about a watermark technique back in January 2006 and the good news is it still works in 2012. Work around warning, it involves a dwg file with the text and using a legend view but it does work.
    Revit Guru
    July 28, 2011
    Brisbane, Australia
    47
    05:32 AM
    Quote Originally Posted by Steve_Stafford View Post
    Isn't that going to result in the dreaded "as indicated" view scale in most cases...
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,481
    07:32 PM
    Quote Originally Posted by PijPiwo View Post
    ...maybe in 2013
    Thanks Martijn
    Well, to set up maybe. But the drafting views can be saved out to your template so you can reuse them
    May 20, 2011
    Chicago, IL
    210
    02:32 PM
    Quote Originally Posted by mdradvies View Post
    True, but I thought it would be possible with true text watermark somehow.
    Steve's idea is not quite working for me.
    ...I think I stick with Acrobat for now.
    Thanks guys!
    Mr. Revit OpEd
    638
    12:32 PM
    Yep, if you show that on the sheet anyway. With a view title the scale is already there, why show it again...
    For the technique to work I believe the legend needs to be wireframe.
