Results 1 to 8 of 8
Thread: Hyperlinks in Revit
    January 10, 2011
    45
    07:07 AM
    Question Hyperlinks in Revit
    Dear Gurus:
    Is it possible to hyperlink an object in Revit? I would like to have the end user click an annotation symbol in the generated PDF and have it take them to a particular website. If this is not possible, is there a way to have the hyperlink text shortened? Many URLs are way too long. I would like to just have the text displayed like this: link and have the URL hidden. Can this be done?
    Thanks in advance for the help \ advice!
    United States
    1,135
    05:07 AM
    The only idea I have for this is to use a QR Code
    December 9, 2010
    104
    06:07 AM
    I have not checked this, but some information is retained when you export to dwf. The links might be one of those bits of information that is visible and if so, I imagine it will function as a hyperlink...don't know for sure though...
    Kingdom of Denmark
    4,127
    01:07 PM
    Quote Originally Posted by gdoherty0102 View Post
    That┤s pretty clever
    Another option is to use one of the services to create short URL┤s - Like www.bitly.com
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    682
    07:07 AM
    Quote Originally Posted by t1shep View Post
    URLs placed in a parameter of a Revit object DO NOT function as links when exported to DWF.
    January 10, 2011
    45
    07:07 AM
    Thanks for all the responses. We are already using QR Codes on our drawings for various info. However, it is sometimes not convenient or possible to use a smartphone to follow these links. It would be nice if the URL parameter could a bit more flexible - and would work in DWF. Maybe we will see some changes in this in an upcoming version. Thanks again!
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    636
    08:07 PM
    For those of us who do not know can someone explain QR code, what they do, how they work etc etc
    January 10, 2011
    45
    07:07 AM
    Quote Originally Posted by Drew View Post
    QR Codes are like barcodes, but they use a pixel pattern instead of bars. They can be read by smartphones (with the right app, of course) and can contain anything from a URL to contact information or a block of text. More info here: http://code.google.com/p/zxing/
