Results 1 to 6 of 6
Thread: How to print that all lines would be thick lines?
    Member bangobeat's Avatar
    April 14, 2011
    264
    02:42 PM
    Title of thread says everything
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    01:42 PM
    Well, Override graphics in view, set all categories to thick linestyle. Revit prints everything in Thick Linestyle, but you won't notice that when you have all Object Styles set to a thin style.
    April 14, 2011
    264
    02:42 PM
    I was hoping for some kind of function like " print all lines in thin lines". So i have to make manually in Override graphics in view, then in object styles.
    When i change in object styles, is there any DEFAULT function, or save settings as? because if i set line weight to 1, hit save. Previous settings will disappear.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    01:42 PM
    You could create View Templates for this and Override by Category in that specific template. That would pretty much give you a "magic button".
    Member rosskirby's Avatar
    December 16, 2010
    Marietta, GA
    138
    07:42 AM
    Why? What effect are you trying to get that you have no lineweight differentiation? Perhaps there's a better solution than just overriding all the lineweights...
    April 14, 2011
    264
    02:42 PM
    Just colleague of mine asked me this, he wanted to print in pretty big scale with thin lines.
  1. Thin Lines...
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: May 25th, 2011, 05:11 PM
  2. Match Lines
    Last Post: May 19th, 2011, 08:46 PM
  3. Centre Lines
    By Gabriel Black in forum MEP - General
    Last Post: May 3rd, 2011, 01:07 PM
  4. Section lines
    By scrogge in forum Architecture and General Revit Questions
    Last Post: March 18th, 2011, 07:10 AM
  5. Dotted Lines
    By redmonki in forum Architecture and General Revit Questions
    Last Post: January 27th, 2011, 11:13 PM
